Old 05-06-2012, 09:19 PM   #1
Shower Water Pressure
Sure seems low
1 Can you turn the pump on using CG water to build up pressure or is that only for water tank usage.
2 I was looking at some after market shower heads that build up pressure are they any good or just hype any recomendations.
Mike
fiwelsh is offline   Reply With Quote
Old 05-06-2012, 09:28 PM   #2
1. pump is used for onboard water tank or pumping RV antifreeze into the plumbing.
2. Oxygenics Body Spa RV Showerhead - the best rv shower faucet Camping World - Oxygenics Body Spa RV Showerhead - the best rv shower faucet - Product - Camping World
Old 05-06-2012, 10:08 PM   #3
amxpress's Avatar
x's 2
I had an Oxygneics shower nozzle in my Sabre. It really made a difference.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 05-06-2012, 10:56 PM   #4
Had similar issue until.....
I unscrewed the hose at the faucet and then noticed that there was an obstruction. Is it just the shower head? If you unscrew the hose and turn on the water, do you have the same problem?
Another consideration / guess is that if it's just the shower, perhaps there is some lime buildup inside the head. One time that was the case with a shower head I had inside my home (my other "home" and was rectified by soaking the head in a little CLR solution for about an hour.
Patrick Mahoney
2011 Palomino Thoroughbred Ultra Lite
Model T-273
2010 Ford F-150 Super Crew
Equalizer Hitch
pmahoney is offline   Reply With Quote
Old 05-07-2012, 08:23 AM   #5
trudinator's Avatar
Get an Oxygenics showerhead. The difference in pressure is amazing. Now if we could only get them to make a kitchen facuet.....
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 05-07-2012, 09:23 AM   #6
camper_Lucy's Avatar
I agree the Oxygenics showerhead helps, but I also added an adjustable water regulator which helped even more. Adjustable Water Regulator - Lead Free - Valterra A01-1117VP - Faucets & Inlets - Camping World
2011 GMC 3500HD 4x4 Crew DRW Duramax
Pullrite 20.5K
2012 Sierra 365SAQ
2006 Police Roadking FLHPi
camper_Lucy is offline   Reply With Quote
