Old 08-22-2017, 09:34 AM   #1
SLIDE CLOSED - Sticking
Have the Surveyor Model 200MBLE - It has the dinette slide. 2016 model.
Slide worked fine this weekend. Home to unload yesterday... attempt to run slide out and NOTHING. Wouldn't move. No straining motor sound. NOTHING. Checked the 15 amp fuse in my main breaker/fuse panel. Looked fine but changed anyway for good measure. I am plugged into shore power (120). Other 12 v electrical working fine. Battery charged overnight. Still no movement or noise from the motor.
My guess its something electrical. I am fairly new to this and have never tried the hand crank to run the slide out. Thought this might be a start? Read somewhere though that this might (had crank) not be the best next step?? Plan to try and figure it out this evening. Thoughts or ideas greatly appreciated.
gbaldwin is offline   Reply With Quote
Old 08-22-2017, 03:01 PM   #2
Coolharts's Avatar
Check for a 30 AMP fuse, mine blows when using battery power to pull it in, I replaced the fuse with an auto 30 AMP breaker
2017 Surveyor 33RETS with Residential Refrigerator and Inverter
2005 Ford Excursion 6.0L 2WD
Nights Camped 2016 27, 2017 29
2018 25 2019 21
Coolharts is offline   Reply With Quote
Old 08-29-2017, 10:38 PM   #3
Still a NOOB
This. Same thing for my 285IKDS. With my last TT, I learned to push the button to close the slide once it's closed to give myself peace of mind that it is in fact closed. Make the clicking noise. I've found that when I do this with the Surveyor, the 30A fuse blows. Still trying to break myself of that habit. Haven't tried the auto 30A breaker yet, but I heard it's a fix.
2011 GMC Sierra 2500HD SLT 6.0L Vortec Crew Cab / Regular Bed
2017 Surveyor 285 IKDS
Alaskan SS is offline   Reply With Quote
Old 10-10-2017, 05:32 PM   #4
Check the switch on the wall... the wires came off on mine
smouldering1 is offline   Reply With Quote
Old 10-10-2017, 05:48 PM   #5
There is often a fuse or circuit breaker under the TT at the frame. Take a look there for another fuse/breaker.
2011 Traverse LT, 3.6L, FWD
Old 10-18-2017, 06:14 AM   #6
I have a 2018 surveyor 247 and I too have a problem with the dinette slide and blowing fuses once the end of travel is reached. On mine there is a second inline fuse... to access it you need to remove the 4 screws and pull back the switch panel andthe wiring... it should be right there on that glob of spagetti.
ethdeeram is offline   Reply With Quote
Old 01-07-2018, 11:32 AM   #7
I just bought a 2018 200MBLE and also have this issue. Seems pretty crazy this hasn’t been addressed yet by FR given it is a well known issue that is on going for a few years now.
Jbrowland is offline   Reply With Quote
slide
