Old 08-02-2012, 10:41 AM   #1
Slide out and sealing question
Hi all,
I did some searching but I am not sure what this is called.
I was inspecting the slide on my 255RS and noticed that there is a bead of sealant that is on the camper and the slide butts up to. There are some places where the sealant is cracked and broken. I would assume that this is important in keeping water out when the slide is in. What can I use for this?
Also, I am new to this and have been doing a lot of reading but feel a bit overwhelmed sometimes. Seems like every time we go out, a new issues arises This is a '04-05 camper so it has some age on it. I am not really sure what I should be doing in regards to roof and seam maintenance. Are there any good references for newbs?
ellisz is offline   Reply With Quote
Old 08-02-2012, 07:40 PM   #2
bikendan's Avatar
pics are much better than descriptions, often.
Equalizer WDH
Old 08-02-2012, 09:32 PM   #3
I will get some tomorrow. I would think it is similar to weather stripping but it looks like it isdried up.
Old 08-02-2012, 09:47 PM   #4
Triguy's Avatar
A picture would help us to understand the first part about the sealant between the slide and trailer.
As for roof maintenance, here are some of my thoughts.
Its a requirement that you maintain the roof for warranty purposes. More importantly, this little piece of maintenance will save you lots of money and possible heartache down the road.
INSPECT: Do this every few months. Get a tall ladder and climb up on roof (It will support your weight). Use a board if you want to (I don't) and step clear of A/C, vents, skylight, etc. Inspect all seams, gaskets, and any place that the roof material has been cut or drilled. Check closely around A/C, vents, antennas, sewer vent, every screw, and all side seams. You are looking for dry or cracked caulking. Also, look for any signs of bubbling in the membrane and any tears (damage from tree branches, etc).
CAULKING: Do NOT use silicone. I use Dicor 501 Self Leveling for sealing cracks in the existing caulk. Take your tube of Dicor and a caulking gun and simply squirt a dab of the Dicor on anything that looks like a hole or crack. You shouldn't have to remove the old caulk unless something is really wrong with it.
As for cleaning the roof... I am not positive if you have an EPDM or TPO roof. Check the paperwork you got with the trailer. I use Murphy's oil soap to clean my TPO roof. Whatever you have, you want to stay away from anything with petroleum in it. Here's a helpful primer on cleaning an EPDM roof Cleaning the Rubber Roof
Hope this helps!
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-03-2012, 09:48 PM   #5
Here is the pic. I am not sure what the stuff that is coming off is? It is hard now and I assume it really should not be.
Old 08-05-2012, 02:58 PM   #6
MOD Guy's Avatar
That looks like some type of regular household door weather striping (foam rubber maybe) It looks like something the previous owner may have added. Mine has a black rubber "bulb seal" on each side, much like the off white one to the side in your picture.
Mine also has a factory installed drip rail/gutter above the slide out opening.
View of the seals on the underside of the slide out.
And yes, I have some sanding and painting to do. We took it to the beach last weekend, and the salt air is making itself known.
Chuck Roder & Family
'07 Surveyor SV-235RS & '16 Chevy Silverado 2500HD (Gas) Crew Cab
High Springs, FL.
MOD Guy is offline   Reply With Quote
Old 08-05-2012, 03:20 PM   #7
Triguy's Avatar
I agree that looks like foam or thin rubber weather stripping. I suggest stripping that and replacing with an outdoor seal of some type.
Here's a pic of my slideout at roughly the same spot.
Scott
2012 Shamrock 233S
Old 08-05-2012, 08:41 PM   #8
Hmmm. That worries me. I hate when I see things were changed and I don't know why. I need to see if I can find something better.
That drip/rain gutter and slide awning look nice. Wish I had one of those too
Old 08-08-2012, 10:38 PM   #9
It looks like I need some 'D' seal and it appears that this is not a Home Depot item. I should probably replace all sides of the slide since they are showing age. Is there a preferred place to order this? Seem to be on Ebay alot lately ... ;(
Old 08-09-2012, 09:16 PM   #10
Anacortesians
My MH is an '02 and I've had a lot of problems with ths slide-out seals since we bought it in 2010. After a lot of research, I've come to the conclusion that the RV manufacturers (at least Georgetown) are totally clueless about using adhesives.
On my rig, all the slide-out seals have come loose at various places. When I look, the seals are all held in place (or not in many cases) by double-backed foam sticky tape. The surfaces they're stuck to, in most cases, are gloss-enamelled metal frames which clearly have not been roughened (and probably no de-greased) prior to the attachment of the seals.
When I was at Boeing, I spent some time in Materials Technology and we tested adhesive systems for bonding airplane parts together - no rivet holes to make stress concentrations, easier sub-assemly procedures, etc. There are a lot of secondary bits on Boeing (and Airbus) airplanes that are glued together.
Where the RV industry falls down is that they don't seem to understand the need for surface preparation. The mating surfaces must be clinically clean and roughened to give the adhesive enough irregularities to get a good grip. Double-back sticky tape on gloss-enamel metal just doesn't work, guys.
After all my efforts, whoever buys my MH when we're done with it will have a nicely fettled one.
Frank and Eileen
No longer RVers or FR owners
Old 08-10-2012, 04:25 PM   #11
MOD Guy's Avatar
My seals are designed to slide/push into a grooved area in the rail, and then the ends are screwed down. I had to replace the section under the bed when it got caught on the gear track. My local FR dealer ordered it for me (took in a section to show him). I don't remember the exact cost, but it was not expensive. They can order it by the foot.
High Springs, FL.
Old 05-27-2013, 08:14 AM   #12
Attachment 17537
Hi Triguy,
Where did you get that slideout awning?
elliotg78 is offline   Reply With Quote
Old 05-27-2013, 03:20 PM   #13
bikendan's Avatar
Originally Posted by elliotg78 View Post
Hi Triguy,
Triguy's slidetopper came from the factory, i think.
problem is, his slideout is on the side and the OP's is on the rear.
and as far as i know, no slide topper/awning manufacturer has made one for rear bed slide trailers.
i've never seen it as an option on rear bed slide models, nor have i ever seen one installed.
Equalizer WDH
