Old 04-21-2016, 08:37 AM   #1
Slides
Anyone know how to manually move your slide back in on a 240rbs.
nysseja is offline   Reply With Quote
Old 04-21-2016, 09:26 AM   #2
mjones12's Avatar
On the 220 you have to remove a panel on bottom front of the dinette seating area, on the right as you face it. Don't know how similar yours is.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 04-22-2016, 05:24 PM   #3
Renderspud's Avatar
Copied this from an older post. The manual crank on ours is located through the bottom panel under the stove. Hope this helps!
Locate the electric motor for your slide...you might have to remove a wooden panel to get to it. On the motor drive unit you should see a 5/8" drive nut...the same size as on your rigs stabilizer jacks...might have a cotter pin through it. This is the manual drive nut for the slide...rotate it using an electric drill with the appropriate size socket or your stabilizer drive handle or a suitable wrench...clockwise extend, counter clockwise retract (or vice versa...not quite sure)
Renderspud is offline   Reply With Quote
Old 05-31-2016, 08:26 AM   #4
Slides
Thanks i have side track es,motors are located on top of slide.
Have to pop out motor to move slide in.
slide, slide out
