Old 01-30-2010, 09:22 AM   #11
Originally Posted by cfsoistman View Post
All I've ever done whether it was our Pop-up, Trailer or Motorhome is kept them off level in the direction I want the water to flow once it starts to melt. We've had some big storms over the years but I've never had a problem.
Come on Springtime!!!!!
Good point made, I keep my campers lowest point to the rear, I off set about a 1/2 bubble. If the snow you get is dry (powder) it will blow until it starts to melt then the weight of the snow gets heavy. I have never heard of any problems with camper roofs and snow.
Old 01-30-2010, 09:27 AM   #12
dichayer's Avatar
Damn MTNGUY! You do have some snow. It must be the global warming is picking up speed. It is -8 F right now. BRRRRRRRRRRRRR!
dichayer is offline   Reply With Quote
Old 01-30-2010, 10:34 AM   #13
MtnGuy's Avatar
That was a photo of the results of the December storm that came through here. We are not expecting near that much this time......thank goodness.
I am just glad that we don't have your -8. It is clear up to 16 here.
Old 01-30-2010, 06:55 PM   #14
dichayer's Avatar
A heat Wave
Old 01-31-2010, 09:26 PM   #15
acadianbob's Avatar
Beautiful place you have there MtnGuy!! b
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 02-01-2010, 09:10 AM   #16
MtnGuy's Avatar
Thanks, Bob.
Another inch or 2 forecast for tomorrow nite, with another storm headed this way for the weekend.
Old 02-01-2010, 10:16 AM   #17
Originally Posted by mtnguy View Post
Thanks, Bob.
I can't wait.
Hokiehall is offline   Reply With Quote
Old 02-01-2010, 10:17 PM   #18
Do we need a moderator? We went from snow on the roof to forecasting weather across the country. Only kidding, we're waiting on warmer weather yoo, so we can load the bikes and start camping again.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 02-01-2010, 11:47 PM   #19
Last winter we had snow on the ground where I live from Dec 13 thru March 3. Over that period and in between snow falls we had some rain which did not wash away the snow. I did some research in the beginning as the snow was not letting up and found that the weight of fresh snow is 10 lbs per cubic foot. That said on a 32 ft x 8 ft wide trailer we would have 2560 lbs of weight on the roof (with only 1 ft of snow ).
I have read that wet or compacted snow can weigh 2-3 times more. When the snow started piling up last year I was diligent at removing it from the roof of the trailer (I used a step ladder at the side of the trailer and carefully used a push broom).
OREGONCAMPER
2008 Rockwood 8317SS - 2010 F150
2013 Camping Days: 22
2012 89 2011 50 2010 61
OregonCamper's Pics click here
OregonCamper is offline   Reply With Quote
Old 02-04-2010, 03:03 PM   #20
MtnGuy's Avatar
In my #8 post, I showed a 2 foot snow that I didn't bother to clear off of the camper, although I was little concerned. That snow eventually melted, but in the last couple of weeks we got an additional 10" in 2 snowfalls, and I saw very little water coming off of the camper since then. Getting a little concerned with the forecast of 20 to 28" wet snow tonite and tomorrow, I decided to get up there and do some shoveling. The 10" of snow had compacted to ~6", and it was heavy, with slush and ice on the bottom. I very carefully shoveled most of it off with a portable plastic shovel that I have, so the old snow won't contribute to any additional weight with the new snow coming.
I also am prepping the trailer for an emergency shelter, in case we loose electricity.
surveyor
