Old 10-28-2012, 04:38 PM   #1
1SG Page
SP-260 Low Point drains
Friends,
I can't find the low point drains on my SP-260. Anyone know where they're located?
Thanks.
moadeeb is offline   Reply With Quote
Old 10-31-2012, 12:43 AM   #2
Originally Posted by moadeeb View Post
Friends,
Thanks.
They are located on the driver, very rear bottom, side of the trailer. You can not miss them (red and blue pvc pipes). you should be able to access the low point drain for the fresh water on the passenger side between the wheels...about 12 inward.
2010 GMC SIERRA 1500 SLT Alterain
2012 Surveyor SPT 260
OmoYoruba is offline   Reply With Quote
Old 10-31-2012, 11:32 AM   #3
1SG Page
OmoYoruba, looked again and the only thing I saw was a blob of black spray on type foam in the area you mentioned. Wondering if it's under that mess? If so, I'm curious why they would spray over those??? Got the fresh water drain w/no problem.
Thanks for your help.
Old 10-31-2012, 12:12 PM   #4
Campin' in Canada
ParkManCan's Avatar
I have a different TT than yours but that's kinda what they did to mine, almost completely encased them in the spray foam. I was just careful not to dislodge the whole clump of foam and then the caps appeared after a little probing around.
2011 Wildwood 37bhss2q
Permanently Parked
Just me & the DW
ParkManCan is offline   Reply With Quote
Old 10-31-2012, 09:39 PM   #5
1SG Page
Thank you for your help ParkManCan - I am much more confident now to winterize my RV.
