Old 07-07-2014, 10:40 PM   #1
Stereo is always on
Is there a way to turn the stereo off for storage? I bought a battery disconnect, but I won't install it if I am just missing a switch somewhere.
madmaxmutt is offline   Reply With Quote
Old 07-08-2014, 12:58 AM   #2
jtstromsburg's Avatar
Stereo, propane, co detectors all draw a bit of power. If your not plugged in, it'll drain the battery in a few days. Best to either have a battery disconnect or actually remove either ground or power cables from the battery.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 07-08-2014, 07:26 AM   #3
Camper Less Camping
Cajun Po-Boy's Avatar
X2
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 07-08-2014, 08:16 AM   #4
Thanks, that is what I thought. I will go ahead and install the disconnect.
Old 07-08-2014, 11:54 AM   #5
Timex's Avatar
Why does the stereo stay powered up?
I under stand the Co detector but does the stereo stayed powered up to save stations to memory?
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 07-08-2014, 12:04 PM   #6
AquaMan's Avatar
That is correct, and the time (if you've ever set it)
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 07-08-2014, 12:17 PM   #7
Timex's Avatar
I'm sure an RV'er came up with that idea.
I guess if you stayed in 1 place for an extended time, it would be beneficial. I like music as much as the next guy but when I go camping I never turn the radio on. I do run the audio from the tv thru the speakers though.
My stereo in my S/B home stays on similar to this but I can turn it off by holding in a button for a few seconds. It still saves the stations and just shows the time which is 12:00, 12:00, 12:00...
Old 07-08-2014, 12:58 PM   #8
dcheatwood's Avatar
My brother put a simple switch inline to kill power to stereo when not in use.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 07-08-2014, 01:05 PM   #9
fmc
fmc's Avatar
I also put a switch in line and shut off the power to my stereo.
fmc is offline   Reply With Quote
Old 07-08-2014, 06:04 PM   #10
Thanks, I will probably skip that switch. I installed the battery disconnect today.
