Old 07-29-2016, 10:13 AM   #21
wmtire's Avatar
Originally Posted by bobothewizard View Post
So looking at the schematic it doesnt seem as complicated as i thought. It really is only a positive and negative wire broken by a switch on the negative
Bobothewizard, not sure here what schematic you are looking at or I guess switch. If you are talking about the switch to the electric heating element on the Suburban, this switch has no negative wire. The blk wire is 120 volt hot, as this is 120 volt AC house wiring......not 12 volt DC automotive. Please do not confuse them.
The switch just breaks power/continuity on the 120 volt hot leg/line....then the same line goes to/thru the ECO hi-limit/thermostat...then the same line to the electric heating element.
Because you do not have a neutral or ground wire connected to either the switch or the Emergency Cut Off Reset/thermostat...then when you are using you multimeter to test, you have to place the multimeters negative probe on a ground somewhere to test for voltage. You will not be able to place one probe on one terminal of the switch and the other probe on the other terminal...since you are testing voltage and have to have either a ground or neutral to do such.
Same applies to testing the ECO/thermostat too.
Hold on and I will get you another thread I explained this in to help.
2011 Flagstaff 831 RLBSS
Real men don't eat honey. Real men chew on bees.
Old 07-29-2016, 10:19 AM   #22
KyDan's Avatar
Originally Posted by Brewhedd View Post
Darn, I don't know why I would bother to use a $100.00 Fluke Multimeter when Harbor Freight has them for $6.
I have both as well.
The HF free meter (with coupon) works! IF someone just needs to check
voltage present or continuity the HF will work.
If you are trying to check battery charge level where you need accuracy
down to 1/10 of a volt then the Fluke is probably better.
The Fluke is definitely more rugged. Mine is mine safe so it's water proof and explosion proof. Or so they claim. I'm not going to toss it in the pool to find out!
Now back to the water heater discussion.....
Peace!
Dan & Rita D
2004 5.3L Silverado 1500 ext. cab 2WD
Blue Ox WD hitch, AirLift load levelers
2013-41, 2014-31, 2015-40, 2016-44, 2017-36
KyDan is online now   Reply With Quote
Old 07-29-2016, 10:24 AM   #23
wmtire's Avatar
Here is the thread I was looking for to help explain how to test the switch and/or hi-limit/thermostat. You can read from this post forward as it may help in solving your problem. This member originally was not checking voltage correctly using his multi-meter, but it got all fixed up.
Suburban Water Heater problem
Also this site may help, and has links to using a multimeter:
RV Electric
We also keep a pretty detailed Suburban water heater operational FAQ here, including schematics:
Suburban's electric switch and much more
Old 07-29-2016, 10:37 AM   #24
wmtire's Avatar
Here is also a pic of the Suburban resettable ECO hi-limit/thermostats that are under the rubber covers. The one on the left is to the 120 volt AC electric element. You may notice that the small thin fusible link (to the far left) is burned out between the hi-limit and thermostat sides (thus will need replacing as it will not allow 120 volts to flow thru to the element now). This happens fairly common if the electric heating element burns up.
You can see this situation visibly, without using a multimeter. However, if the hi-limit or the thermostat is bad, you still have to check with the multimeter.
Old 07-29-2016, 12:38 PM   #25
wmtire, awesome. Thank you, i am reading those threads now. I can even see i was pushing the wrong reset button, i was hitting the one on the right.
bobothewizard is offline   Reply With Quote
Old 08-08-2016, 09:41 AM   #26
Installed a new thermostat this past weekend and all is good. I cant thank you guys enough, you all were a tremendous help!
Old 08-08-2016, 09:46 AM   #27
wmtire's Avatar
Excellent, and thanks for letting us know the final outcome. It may help others in the future who are searching for the answers to similar problems.
Old 09-29-2016, 08:39 AM   #28
Easier to resurrect an old thread but does anyone know what size socket fits the anode bolt to drain the tank for winterization?
Old 09-29-2016, 08:55 AM   #29
wmtire's Avatar
inch and 1/16th ( 1 and 1/16th)----- and use a six point socket so as not to round the edges off the anode.
EDIT: This thread in the FAQ section may help also:
Anode rod removal
heater, water, water heater, suburban
