Old 05-03-2016, 10:39 PM   #1
Surround sound
The sound bar in our unit will not play the TV. The TV did not come with an owners manual and the quick guide is no help. I've read elsewhere in the FR Forum that this a common problem but I haven't found any answers. Any ideas would be appreciated.
Humteddy2
2014 Silverado Z71 LTZ 1500
2017 Surveyor 285IKDS
Humteddy
2017 Surveyor 285 IKDS
2016 GMC Sierra Denali HD 2500 Duramax
Humteddy2 is offline   Reply With Quote
Old 05-04-2016, 02:47 PM   #2
Renderspud's Avatar
I had to go into the TV settings and turn on the audio out. Then my soundbar works but the TV speakers don't.
Renderspud is offline   Reply With Quote
Old 05-04-2016, 04:32 PM   #3
The dealer called today and they are sending a new sound bar free of charge. While I have it out I'll be replacing the screws that hold it with Velcro. PITA to have to take the fireplace out to remove the sound bar.
Humteddy2
Humteddy
Old 05-07-2016, 10:33 PM   #4
Herlitzke's Avatar
I am having the same issue. TV sound isn't coming through the sound bar. Did you get your new one yet and get it working?
Herlitzke is offline   Reply With Quote
Old 05-09-2016, 12:22 PM   #5
BCCamper's Avatar
My unit came without a tv we added one and running it through the main sound system it works great. There is TV input RCA cords that come out of the tv and into the main control centre. Sound bar comes on with the tv no problem.
BCCamper is offline   Reply With Quote
Old 05-09-2016, 02:11 PM   #6
I've read where this is a common issue with these soundbars. That's why I made sure they tried it at my PDI. We tried all different configurations to get it to work and it won't. Still waiting on the replacement unit.
Humteddy2
Humteddy
Old 06-09-2016, 01:21 PM   #7
Herlitzke's Avatar
Humteddy... Did your replacement ever come in and did it fix it?
2009 GMC Sierra 1500
2017 Surveyor 32BHDS
Old 06-10-2016, 08:43 PM   #8
k1dirty's Avatar
I had the same problem with the sound bar. It wouldn't play the TV. It turned out to be a setting in the TV. I went to the audio section in the menu and if I remember right, all I had to do was turn off the speakers and it redirected the sound to the RCA outputs.
k1dirty is offline   Reply With Quote
Old 06-14-2016, 03:49 PM   #9
Herlitzke's Avatar
I have tried changing that setting but no go. Checked all connections, tried different audio out cables etc. think only thing I didn't try was another TV to see if it is the tv or sound bar.
Old 06-14-2016, 07:00 PM   #10
Coolharts's Avatar
If it is a Jensen there is a setting that is almost hidden that turns off the tv speakers and makes the audio go out the sound bar and speakers. Also, the Jensen composite cable is junk, mine broke, replace it with another.
2017 Surveyor 33RETS with Residential Refrigerator and Inverter
2005 Ford Excursion 6.0L 2WD
Nights Camped 2016 27
Nights Camped 2017 0
Coolharts is offline   Reply With Quote
