Old 06-27-2013, 10:36 AM   #1
mjones12's Avatar
Surveyor 220 fuses
Can someone tell me where the fuses for the slideout and power awning are located on the 2013 Surveyor 220? I figure if there's ever a failure, that will be the first place I'll want to check. Thanks.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is online now   Reply With Quote
Old 06-27-2013, 10:43 AM   #2
TURBS's Avatar
I would have thought whom you bought it from would have showed you?
There is also a few circuit breakers and maybe a fuse near your battery and positive cable.
You should have gotten a manual crank for your slide out.
More often than not its your stabilizer crank.
Turbs
They should be in here.
Old 06-27-2013, 11:14 AM   #3
tanddc's Avatar
As Turbs said I would have thougth they were in the WFCO box. I cannot verify for sure but I was not told otherwise on my walkthrough. Guess I should try to look tomorrow (perferably before the 5th beer )
tanddc is offline   Reply With Quote
Old 06-27-2013, 11:17 AM   #4
TURBS's Avatar
After six things go a little goofy I'm told.
Old 06-27-2013, 12:31 PM   #5
mjones12's Avatar
I can look in the main fuse box, but I thought I read on here that the slideout fuses were often located somewhere apart from the other fuses.
Old 06-27-2013, 12:54 PM   #6
TURBS's Avatar
Not always.
My sabre s.o. fuses are in the distribution panel as shown.
Turbs
Old 06-29-2013, 08:17 AM   #7
tanddc's Avatar
Fuse for the slide out is located in the WFCO box with the rest of them. (Don't worry turbs no beers were harmed in this undertaking)
Old 06-30-2013, 10:38 PM   #8
Yes, they're behind that door with the rest of the fuses. They're # 8 and #9 on the right side of the panel.
Deciding between two Surveyors
This will be our first RV
Palm Breeze is offline   Reply With Quote
Old 07-05-2013, 06:37 AM   #9
mjones12's Avatar
Thanks to everyone.
Old 07-05-2013, 08:49 PM   #10
The fuses that your are concerned with are located in the converter. This united is located underneath the sink unit. Once the door is opened, by pressing on the top area, the fuses (automotive|) are marked.
Terry T is offline   Reply With Quote
