Old 03-16-2016, 04:33 PM   #1
oldcat's Avatar
Surveyor 220RBS Bathroom Door Mod
The only thing we didn't like about our SP220 was that you had to deploy the slide a ways to get into the bathroom. I solved the problem by making a "dutch door". The bottom half opens enough to get your legs through, and the top opens all the way. The two halves can be held together with a small bolt so that the door works normally when the slide is out. The door is hollow core so I had to add some wood fillers where the door was cut. Other than that it is a simple project and costs less than ten dollars for the hardware.
Safe travels.
ID:	102100   Click image for larger version
2013 GMC Sierra 2500HD 6.0 Vortec
2014 Surveyor Sport SP220RBS
oldcat is offline   Reply With Quote
Old 03-16-2016, 05:23 PM   #2
Great idea and nice work!
Old 03-16-2016, 05:24 PM   #3
pt1655's Avatar
hidee ho
Great post & great pics, good job! We also have the Surveyor 220 and when we first got it in early 2013, I put in a folding door in place of the wood door. Unfortunately I used a door from Home Depot that proved to be too heavy and was pulling the very thin ceiling down so I took it out after that and put the wood door back on. We've just gotten used to putting the slide out a bit to use the bathroom while traveling. And, my wife now absolutely refuses to let me touch anything to do with that dang door even tho, like your mod, there are good ideas out there! Sigh.
ID:	102104   Click image for larger version
2013 Forest River Surveyor SP220 Sport 25'
2012 Ram 1500 4X4, 5.7L Hemi quad cab
pt1655 is offline   Reply With Quote
Old 03-17-2016, 09:30 AM   #4
mjones12's Avatar
Oldcat: that IS a great solution.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 03-18-2016, 06:12 PM   #5
oldcat's Avatar
Thank you for your positive comments. We keep a cover on the TT if we will not use it for a month or more, and since it was not possible to deploy the slide with the cover on, the bathroom was off limits. Now we have full access. Also, since the water pump switch is in the bathroom, I can now wash my hands after "dumping" with the slide in
We are back on the road next week, if you see an SP220 with CA tags, ask for Oldcat, there is always room at our campfire.
Safe travels.
Old 04-08-2016, 09:59 AM   #6
pt1655's Avatar
oldCat, Me and the Mrs. moved here to northern Az. in early 2003 after retiring from PacBell in Sacramento after upteen years. Have a great time and happy camping, hope to see you on the road! PT1655
door, roo, surveyor, modifications
