Old 07-02-2013, 05:59 PM   #1
rmm2435's Avatar
surveyor 234 problems
Camper battery went dead. Hooked up to the truck then a knocking noise was coming from the fridge I think. The "check" light turned on. Plenty of lp. Any suggestions. Also my biggest concern is the fresh water tank. When filled all the way it drains into the "basement" to about 1/3 of a tank. The leek must be before the pump. Does anybody have a suggestion of how and where to start looking? Thanks all
rmm2435 is offline   Reply With Quote
Old 07-02-2013, 06:00 PM   #2
rmm2435's Avatar
Fr surveyor 234 2008
Old 07-02-2013, 08:23 PM   #3
Was it a fast leak, or slow leak?
Unless there is a crack in the tank, the only way it should drain relatively quickly (other than through the pump) is the low point drain for the tank itself. There's usually a length of pipe/tube from the low point drain on the tank, usually to a threaded cap which can be removed to drain the tank. I'm thinking that tube/pipe might have come loose at the tank end. Look under the trailer for this drain pipe, then follow it up to the tank (you'll need to remove the underbelly cover if you have one).
SCOC is offline   Reply With Quote
Old 07-03-2013, 10:30 AM   #4
rmm2435's Avatar
Yup a crack in the tank. Know any great adhesives, patch kits?
