Old 08-19-2010, 04:20 PM   #1
Unhappy Surveyor 235RKS de-lamination
I have a 2009 235RKS and about a month ago I noticed what appears to be
de-lamination on the bottom corners of the rear slide. I check the seal around the slide and it appears to be in excellent condition. Could this be caused by something other than water penetration and is it something I should be concerned about. I have attached photo's.
Regards
Name:	P1010735 - 2010-07-17 at 13-51-16.jpg
ID:	3193   Click image for larger version
Name:	P1010736 - 2010-07-17 at 13-51-23 1.jpg
ID:	3194   Click image for larger version
Name:	P1010737 - 2010-07-17 at 13-51-27 2.jpg
Sabre99 is offline   Reply With Quote
Old 08-19-2010, 05:27 PM   #2
milzat's Avatar
Regards
It's hard to tell exactly what caused the de-lam. FR did have a problem with the Lamination process at one time or another. The only way to tell the source of the de-lamination is to explore the area. With that said, it's best to contact the dealer about the situation.
milzat is offline   Reply With Quote
Old 08-19-2010, 09:14 PM   #3
grhodes50's Avatar
It's best that you get the trailer to your dealer. Let them check it out, document everything and contact Forest River.
Gary & Trish
2019 Nights Camped - 3
Old 08-21-2010, 09:14 PM   #4
235rks leck
we also have a 2009 235rks and also had the same thing happen to us . it was coulded by the white sealing tape on the top of the side and water got in and did the same thing to owers so we called the dealer and fr. so thay repladed the hole rear side with a new one. things happen now and then as long fr they do what's right i have no problem.
2003chevy is offline   Reply With Quote
Old 08-24-2010, 06:22 AM   #5
Our '08 255RS did the same exact thing. I retaped the top of the slide (Later I did all the roof seams and edges) with the Eternabond Tape. But some day I would like to replace the rear slide wall. We bought ours used, out of state from a couple 8 mos after they bought it new. So taking it to a dealer is not an option.
Taylorsville, MD
2001 Toyota Sequoia
2008 Surveyor 255RS
Henlsey Arrow & TruControl Gold
Longest Trip: 2009 - 4 Weeks - 8030 miles Coast to Coast.
zbittsurveyor is offline   Reply With Quote
Old 08-24-2010, 08:04 AM   #6
Too answer should you be worried, just keep in mind the value for trade or re-sale has just taken a dive most likely by thousands of dollars.
macbwt is offline   Reply With Quote
Old 08-24-2010, 10:23 AM   #7
I am told that campers on the average drop about $1500 to $2000 bucks a year, so when you subtract for delam it drops even more.
Old 09-20-2010, 08:28 AM   #8
Poor workmanship
I just picked up my trailer after having the de-lamination fixed. This was created do to an error during manufacturing. There wasn't any sealant applied to under the trim resulting in moisture entering and causing the paper thin backing separating from the outer shell.
Old 10-05-2010, 11:58 AM   #9
I've seen this happen on a 2009 235RKS but the dealer made good on it and replaced the slideout completely.
2005 Silverado 2500HD Duramax w/Allison (w/EFI Live )
2011 Surveyor 235RKS (customized)
mtl4 is offline   Reply With Quote
surveyor
