Old 04-25-2008, 09:31 AM   #1
Exclamation Surveyor 291 Service
Hi there. Im new to this forum. I am trying to find out how the Cable and Satellite wiring are in the RV that I am working on. It is a SV-291. I know where the cable comes in from the outside but I'm not sure how the Satellite one connects. If anyone can help me i would greatly appreciate it. Thanks in advance.
Tim
mhsrebelguy06 is offline   Reply With Quote
Old 05-08-2008, 12:15 AM   #2
I just have one connection on my 2008 291. I asked the dealer if it was Sat capable and he said ??????.
I am guessing no.
Nights camped in 2010 = 21 nights
2008 Chevy CCab 5.3L 4WD Z71
2008 FR Surveyor 291
Champion Genset
Slpybear, Mrs Slpybear, Three Cubs
slpybeartx is offline   Reply With Quote
Old 05-08-2008, 04:13 AM   #3
If there are two connections on the out side of the camper, then there well be two at the entertainment center and one in the bed room. the two out side and two at the entertainment center will be mark, " ant " and " cable ". The one marked cable is also for satellite, the one in the bed room is for antenna only.
Old 05-08-2008, 06:30 AM   #4
Head Rambler
If it has satellite "Prep" it will have two cables and one will be marked as such.
I believe your 291 only has one cable and it's for cable tv. It goes from the outside F connector to the antenna amplifier. Satellite requires a DC voltage be passed through the cable to the dish which the antenna amplifier blocks. You'll need to either modify the cabling at the amplifier or run a separate cable for the satellite. A separate cable is the best way but it's a pain to install in most RV's so most people just modify the cabling at the amplifier and it works ok.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 05-27-2008, 12:32 PM   #5
Any info on how to change the cabling at the amplifier?
Champion Genset
surveyor
