Old 06-18-2013, 12:16 PM   #11
Originally Posted by acadianbob View Post
The leaf springs making the trailer sit higher would be a problem for me on any new Surveyor. My barn door is only 10.5 feet high. Also, sitting higher raises the center of gravity for handling and puts the trailer further up into the air stream; I would think that that would affect fuel economy.
I agree in therory there should be a small difference. In my experience, I've towed my SV264 with and without axle risers installed, which make a 3.5" difference in overall height. Other than having to adjust my hitch height to compensate, I haven't noticed any difference in handling or fuel milage. This includes travelling a significantly twisty coastal highway at about 80km/hr, wind gusts, passing trucks, etc. My barn door reacts pretty much the same as my barn door + 3.5". Now to be fair, when I adjusted for the hitch height, at the same time, I also increased my WD to throw more weight forward since I knew I needed to do this based on my last scale weighing and it was the perfect opportunity when the head was taken appart. I did that for weight distribution, not trailer stability, but could this have also compensated for some negative effect of raising the trailer? can't say, but in the end I don't notice any significant differnce from the trailer before or after all these adjustments.
I'm not sure how much height difference a leaf spring vs torsion axle makes, but it's likely in the same ballpark as my axle risers.
SCOC is offline   Reply With Quote
Old 06-18-2013, 12:25 PM   #12
daydreaming about camping
jeeplj8's Avatar
When we looked at a 2013 SV305 this was a significant selling point in my opinion. I liked the idea of torsion axles on that trailer. Yet the trailer did not sit any lower than other leaf sprung trailers. For example, FR lists the SV305 height as 11'3"; yet Coachmen lists my 320 BHDS height as 10'11".
For the record, my 320 is taller than that.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 06-18-2013, 12:30 PM   #13
avolnek's Avatar
Not to be an ***** but my sv305 stands 10'9" at the top of the AC when leveled... The brochure also says the 301,303 and 305 all stand this tall.
not that it really matters, especially only 4" of diff.
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 06-18-2013, 12:34 PM   #14
jeeplj8's Avatar
hmm...going by the info here for the 305:
Surveyor Travel Trailer by Forest River
If yours is 10'9" to the top of the A/C then yours is definately shorter than mine...
not to be *****...
Old 06-18-2013, 12:39 PM   #15
avolnek's Avatar
That's funny actually... I wonder if that's not for the 2014 model...
I will see you 1 site and raise you two!
Surveyor Travel Trailers by Forest River
you'll have to open the brochure on that one...
New 2013 Forest River RV Surveyor Select SV 305 Travel Trailers at AC Nelsen RV Omaha Nebraska AC Nelsen RV
too much time to read and research will drive a guy absolutely nuts!
Old 06-18-2013, 12:44 PM   #16
jeeplj8's Avatar
Crazy - so on the specs (from the green menu on the right hand side of the page) FR lists it at 11"3', but in their own brochure they list it 10'9".
And people wonder why we tell them the numbers from the factory are complete BS.
Now if the specs have been updated for 2014 that would suggest the new trailers are going to be 4 inches taller. yeah - that is a bummer for OP and his barn door.
I am actually thinking of lowering our trailer.
Old 06-18-2013, 01:03 PM   #17
MtnGuy's Avatar
Guess I'll have to keep the one I have!!
Yeppers, I am going to have to keep my SV 263, too. Love the torsion axles. It just seem to float going down the road.
Old 06-18-2013, 06:22 PM   #18
acadianbob's Avatar
All I know is that our 235RKS is 8.5 feet at the roof line plus air conditioner. It sits less than 10 feet tall. The new 235RKS is apparently nearly a foot taller. Guess we'll be keeping our current trailer for quite some time!
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 06-18-2013, 06:53 PM   #19
MtnGuy's Avatar
Our 263 is 9'10" to the top of the AC. It rides low to the ground, but that is probably 1 reason that it tows so well.....along with the torsion axles. I gotta be careful getting in and out of some gas stations......I take the dips at an angle. I have only rubbed the skid bars 1 time..........probably took a chunk out of the pavement of that gas station.
Old 06-19-2013, 04:39 PM   #20
schrederman's Avatar
Definitely a cost-saving move... I wonder how much they dropped the retail price... hehe...
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
