Surveyor - cant drain or pump antifreeze from potable tank
Today 12:21 AMBtennant
I have a 13 Forest River Sport (33'), w/ tankless hw heater. To winterize, I went under the potable fill, found a small white line, opened it and drained the water, closed the drain pipe, then poured 3 gallons of antifreeze in the potable tank, which opening was directly above that drain line. This is what my manual said to do. I went inside, turned on my pump, and waited for the af to come out. After 5 minutes of water coming out, then very foamy water, then a trickle of water, I never got any pink, so I turned off the pump. I have no idea how it could have produced clear water for that long w/o any antifreeze coming out. After looking on the inside, I then found the bypass valve with hose under the fridge, switched the tee valve over, put the hose into a bottle of af, turned the pump back on, and af came through the sink. So, my pump works. I went outside, opened up the same line underneath that I did earlier (to get af out to use with the bypass house inside), but nothing other than a trickle of water came out. I found a 2nd line feet from it, opened that line, but only a trickle of water came out of it also. No antifreeze from either drain line!!!!!!!! So, where did my 3 gallons of antifreeze go that I poured into the potable tank, and why won't my pump pull it from the potable tank? By the way, I have an underbelly that keeps me from actually seeing the tanks. I'm very confused. Thanks in advance to anyone that can help.
