I can't comment on the type of connection/port you may have, whether it's just a capped off T, or a quick connect port , or screw connection. But it is probably fed from the low pressure side of the regulator up near the tanks. So my first thought is, even if you get connected, what are you going to do with it? If you're going to run it to a BBQ for example, you won't have enough pressure unless you remove the regulator on the BBQ. If you will do this then OK, but if you don't want to modify your propane equipment then you need to run a hose directly from the tank(s) before the regulator to get full pressure. Bottom line is that you can't run propane through 2 regulators and expect things to work.
I throw a 20# tank in the back of the truck for the BBQ. Or you can buy a T valve, and extension hoses to run a BBQ (and other LP equipment) right off the trailer tanks.
