Old 05-23-2012, 12:38 PM   #1
bob213's Avatar
Surveyor Select 14" Rim Ratings
Has anyone found the stamp on the rims that come on the new Select models that tell their weight capacity? I'd like to go to a "D" rated tire, but don't know if they will handle the pressure. They might be stamped on the inside, but I can't see it on the outside. I have "C" rated from the factory.
bob213 is offline   Reply With Quote
Old 05-23-2012, 01:25 PM   #2
Fire Instructor's Avatar
I had same issue - no stamps on the rims. had more than one tire dealer tell me I'd be fine at the 65 psi needed for the Kuhmo 857's (D Rated), as long as I replaced my stems with a better stem, which I had planned on anyway.
Fire Instructor
2022 Coachmen Leprechaun 319MB
2022 Ford Ranger toad
Fire Instructor is offline   Reply With Quote
Old 05-23-2012, 02:08 PM   #3
bob213's Avatar
Di you go with the 185 or 195 Kumhos?
Old 05-23-2012, 02:32 PM   #4
I went with the 195's. I really don't understand it, but a 205/75R14 is equal to a Kunho 195R14, because the Kumho is an "82 aspect" (European measurement) and not a 75 aspect.
Got that from several sources....
Fire Instructor
Old 05-23-2012, 04:32 PM   #5
bob213's Avatar
Thanks Fire Instructor...I put the Kumho's on my boat and bought the same size as the ST tires I had. Thankfully I had the clearance for them to fit because they were much bigger. I'm really happy with them so far. 2 years on a 33 ft. boat trailer and they show no signs of wear.
Old 05-23-2012, 05:20 PM   #6
acadianbob's Avatar
I put 195 Kumho's on my rims with no problems. Metal valve stems are required. The Kumho's are great.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
acadianbob is online now   Reply With Quote
Old 05-24-2012, 09:29 AM   #7
schrederman's Avatar
Great info... thanks, again! I'll be buying these when the time comes...
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
