Old 11-12-2015, 09:47 PM   #1
Surveyor television
We have had our 2013 SP 260 for a while and just today tried to play a DVD on the TV on the outside. I didn't have much time to actually troubleshoot it but I was not able to get video outside. Any Surveyor owners know the trick?
2017 Keystone Cougar 28RDB
Buck1032 is offline   Reply With Quote
Old 01-25-2016, 07:58 AM   #2
First see if you can play inside the camper ,then find connections and make sure they are ok.
Donald 1 is offline   Reply With Quote
Old 01-25-2016, 08:17 AM   #3
AquaMan's Avatar
I would first check to see if you have any RCA cables going to the outside TV. If not, then your outside TV is not set up for DVD. This is most likely the case. If by chance you do, then I would look for a signal splitter/switch.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 01-25-2016, 09:43 PM   #4
AguaMan nailed it. I will revisit this problem in the Spring. I will run A/V cable's to hook up when the TV is placed outside. We camped over Thanksgiving with friends so there were 3 kids and I was wanting to set the TV out for a movie night with popcorn. It didn't happen but it will happen the next time I will make it happen. I'll just have to convince the DW to let me put a hole and an A/V connection on the outside skin.
surveyor, television
