Old 03-12-2012, 09:26 AM   #1
LunaTech's Avatar
Surveyor wheel bearing grease
I am doing a little spring maintenance on my TT and was pretty sure what grease to use in the hubs for the bearings but called Forest River to verify I was correct. They confirmed my best guess and told me to use a Lithium complex #2 grease. Just though I would pass along the information if anyone is interested.
Jeff
Foothills of NC
2012 Starcraft Autumn Ridge 309BHL
2004 F-150 4x4 Super Crew
Equalizer WDH
2000 Kawasaki ZRX1100
LunaTech is offline   Reply With Quote
Old 03-12-2012, 10:14 AM   #2
MtnGuy's Avatar
I use Red & Tacky #2 by Lucas products. I checked all of the stats recommended by Lippert Axles, and this met or exceeded the number. My axles run nice and cool.
Old 03-12-2012, 10:16 AM   #3
Mountainmanbob's Avatar
from then on
yes we learn with time
paying just a little extra
is usually well worth the price
when we got a mechanic at work
that truly knew his stuff
from then on
the City only bought the quality grease
but
as I also noticed from
my experience as an equip tec
regarding some of our operators
any grease
is better than none
Mountainman
Mountainmanbob is offline   Reply With Quote
Old 03-12-2012, 10:18 AM   #4
stevengb's Avatar
Thanks for the heads up! That is an area that sometimes gets overlooked.
Steve and Michele Bassett
2014 Surveyor Select SV305
2005 Ford F250 Lariat SuperCab 6.0 TurboDiesel
stevengb is offline   Reply With Quote
Old 03-12-2012, 10:25 AM   #5
LunaTech's Avatar
Yea, it gets overlooked until you are sitting on the side of the road with locked up wheel due to failure of the bearing. I've been there done that and don't want to do it again.
@ Mountainmanbob: I do agree that any grease is better than none but some types of grease don't really play well together and sometimes the wrong type will get you by but cause headaches later. I've been in industrial maintenance for 20+ years and this has got me a few times.
Jeff
Foothills of NC
Equalizer WDH
Old 03-12-2012, 11:19 AM   #6
TURBS's Avatar
Megaplex xd5 #2 used in off road and mining.
conoco product
Old 03-12-2012, 12:54 PM   #7
acadianbob's Avatar
I'm sure there are tons of products out there that will do the job; but this is useful information. I've been using NAPA's best wheel bearing grease. Hubs are nice and cool; even on long, hot tows at freeway speeds. The big deal is "grease your hubs frequently".
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 04-15-2012, 11:33 AM   #8
schrederman's Avatar
Mine has the grease zerks in the hubs... But the dealer said don't use them. He said they're having a lot of problems with the grease going where it shouldn't... into the brakes... yikes!!!
Anyone else know about this problem? Couldn't I just take the drum off and make sure when using the grease gun?
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
Old 04-15-2012, 01:42 PM   #9
MtnGuy's Avatar
If you take the drum off, then you won't be greasing the bearings, as the bearings come off with the drum. Push grease through the zerk, and it is just gonna come out the holes in the back of the spindle.
Old 04-25-2012, 04:42 PM   #10
Surveyor Fan
I recently purchased a 2007 SV-235RS. I love the trailer, and have use it quite a bit in the last 4 months. Can anyone point me towards a step by step or how-to on repacking these bearings? It's been at least 13 years since I've had to do that on a trailer, and I'm a little foggy.
Thanks,
TimR><>
timr21 is offline   Reply With Quote
Old 04-25-2012, 05:00 PM   #11
acadianbob's Avatar
Do you have the EZ-Lub hubs? If so, I'd just use those. It's a zerk in the middle of the hub. I've got approximately 25,000 miles on my Surveyor and that's all I ever do. The hubs run nice and cool.
Old 05-01-2012, 05:02 PM   #12
Surveyor Fan
Where does one get the #2 Bearing grease mentioned above? I checked on the AutoZone site, and didn't see it. Maybe Napa?
TimR><>
2007 Surveyor SV-235RS
2011 Ford Econoline E-350 XLT Wagon
Plenty o' room for me, my wife, and our six kids!
Old 05-01-2012, 05:23 PM   #13
Herk7769's Avatar
TimR><>
Ask for type 2 Lithium tube grease with a minimum 440 degree drop point.
Every auto store stocks a brand with these characteristics.
NAPA carries:
NAPA AUTO PARTS
HAM CALLSIGN - KC3FFW
Old 05-01-2012, 10:19 PM   #14
Sgt. Schultz's Avatar
Personal preference Lucas RedNTacky
Info at Products : Lucas Oil & http://www.lucasoil.com/images/media..._RedNTacky.pdf
This may help in understanding what to look for :
http://www.reliabilityweb.com/art04/..._of_grease.pdf
PT Avenger 33BHS-TE
GMC 2500HD SLE 4x4 Crew Cab 6.0 with 4.10's
Sgt. Schultz is offline   Reply With Quote
