Old 05-06-2013, 04:47 PM   #1
surveyour 291 owners leak question
HI there i have a 2007 surveryour 291 and when it rains i have a leak under the cabinet under sink. i noticed the shelf under sink along the metal rail( which i believe is the slide out rail) is all wet. i cant seem to find any threads about this now. i have thoutght i saw a thread here about the white seal collecting water. But it leaks while slide is in and closed up. i will post pics
campfun is offline   Reply With Quote
Old 05-06-2013, 05:31 PM   #2
Check the small seals on the face of the slideout. The ones which face out. I put very detailed pictures of such a leak ....take the strips out and check and seal each and every screw and the strips. That is how and where it comes in, and then travels right into the white interior strips through the channels.
2009 Ford F-150 XLT/XTR 5.4l, CrewCab. long bed
2011 Surveyor SV-291
Goomph is offline   Reply With Quote
Old 05-07-2013, 10:46 AM   #3
r u talking about the white ones on the outside of the slide out. where the screws would be. or the black ones between the slideout and the camper itself.. i dont see your pics either. thanks again.
Old 05-07-2013, 11:04 AM   #4
White ones , the strips of plastic which they cover the screws .. they go into inserts ...
My pictures should still be available , I am surprised you can not see them. Also all the corners have to be cleaned up and redone.
Old 05-07-2013, 11:07 AM   #5
Piece of junk ? I think so ...
Shows pictures of where the water accumulates
Old 05-07-2013, 11:16 AM   #6
I had the strips and corners marked in a picture but I can not find it ... You will know what I am talking about though.
Old 05-07-2013, 11:18 AM   #7
Yes now i see.
