Old 08-26-2014, 10:19 AM   #1
SV235RKS Jacking and Jacking Points
I just installed my trailer lift. While doing that, I verified my fear of jacking this trailer up. I have no idea how you would change a flat on the side of the road. The passenger side of the trailer has a gas line running underneath that is WAY to tight to the frame. The plastic covering underneath shouldn't be near a jacking point, but there is (understandably) no break in that covering. The jack can only ride about half of the frame width which is just plain dangerous. I used large floor jack for this installation. Surveyor should leave some obvious jacking points with NO obstructions, but there are not any near the wheels.
My questions are:
Where does everyone place their jack?
What jack do you use to change tires on the road?
My trailer didn't come with a jack, was it supposed to?
madmaxmutt is offline   Reply With Quote
Old 08-26-2014, 10:50 AM   #2
mTn_biKer65's Avatar
I've built a trailer-aid out of wood for around the house. Some take this on the road with them but in the unlikely case that I get a flat I'm going to roll the good tire onto leveling blocks until it's high enough to make the change.
Trailer-Aid - Camco TRAILER AID - Towing Accessories - Camping World
Also, there's a piece of steel the runs along the frame rail where the axles are mounted. You can use a bottle jack here as well.
Nights camped
2007 Shamrock F19 hybrid - 2010 (22 nights), 2011 (24 nights), 2012 (11 nights)
2013 Surveyor Select 235RKS -
2012 (6 nights), 2013 (32 nights), 2014 (26 nights), 2015 (37 nights), 2016 (14 nights)
mTn_biKer65 is offline   Reply With Quote
Old 08-26-2014, 11:13 AM   #3
Thanks,
I wondered if an Anderson leveler would raise it high enough, but I will look for the Trailer Aid. I got an offline response about Blaylock EZ that seems very similar to the Anderson leveler. I will check them both out.
Thanks again!
Old 08-27-2014, 04:58 PM   #4
I did end up with a Trailer Aid. I looked at the Blaylock EZ Jack. I found that it costs and weighs more. I tried to find the Anderson version locally, but couldn't find any place that sold it. The Trailer Aid will certainly meet my requirements, so that is the way I went.
Thanks again for your suggestion mTn_biKer65.
Old 08-27-2014, 05:30 PM   #5
I have used the Trailer Aid on my last trailer and it worked well. I have also used "leggos" leveling blocks to make a ramp on a friend's trailer to elevate the good tire. I do carry a floor jack and a bottle jack with me, but the other systems work easier.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 08-29-2014, 07:12 PM   #6
acadianbob's Avatar
I use a bottle jack. I also have a 235RKS. I put the jack between the two axles and just lift it up using the I-beam.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 09-06-2014, 03:37 PM   #7
MOD Guy's Avatar
I have done the same thing when working on a HUB in the driveway. When on the road, I have used my drive on level blocks with the good tire to get the bad tire in the air. I have done this with the previous and current camper more times than I like, but have not had to do it in a long time (I have better luck with bias-ply tires).
Chuck Roder & Family
'07 Surveyor SV-235RS & '16 Chevy Silverado 2500HD (Gas) Crew Cab
High Springs, FL.
MOD Guy is offline   Reply With Quote
