Old 04-16-2012, 03:23 PM   #1
SV264 Bedroom TV Mount
There is no sticker on the wall indicating where the backing for the bedroom is. I assume it is over the power and cable outlet, but since there is a pocket door, I don't want do anything to interfere. I called the dealer about a week ago, and was told they'd check with FR. Nothing yet! I'm a little worried that after sales service may be lacking!
Thanks - Rick
2016 Chevrolet 3500HD DRW
2018 Rockwood Signature Ultra Lite 8290BS
bikeman911 is offline   Reply With Quote
Old 04-16-2012, 06:55 PM   #2
schrederman's Avatar
I asked my dealer the same question. The wall where the pocket door travels is unsupported. Mine has a trim strip that divides the unsupported wall and the reinforced wall area, where the TV outlets are. My dealer said there's wood in that part for TV support. I just wish they had added the mount at the factory. I'll be ordering one like the one outside under the awning, and adding it to the bedroom wall. I can get one for $29.99...
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
Old 04-16-2012, 07:06 PM   #3
TURBS's Avatar
IF theres no sticker saying where to put a tv mount it "normally" means theres no provisions to and you should not .
But I am no expert in this area since both mine had provisions . good luck !
Old 04-16-2012, 08:14 PM   #4
Where did you find it for that price?
Old 04-16-2012, 08:26 PM   #5
Drinkin beer on the beach
Rod Johnson's Avatar
Can you check it with a stud finder?
I have plans to eventually add one to my bedroom, but haven't gotten around to checking for the support yet. I did the knock test, and so far its been inconclusive...
2014 Silverado 2500 6.6L TD and 4X4
2011 Carson Standard Duty Car Hauler
2012 Forest River Stealth SK2112
Rod Johnson is offline   Reply With Quote
Old 04-16-2012, 08:27 PM   #6
DDC
DDC's Avatar
My 2012 SV 264 came with a mount already in the bedroom, only thing is you only get the wall mount and not the piece that goes on the tv.
DDC is offline   Reply With Quote
Old 04-16-2012, 10:27 PM   #7
We got a parts and accessories catalog with ours. This is an ASA Electronics part number 22-1037, on page 388. It's a plain mount and doesn't swivel or pivot. I didn't think there's be room for all of that, so I will be getting the simple one. There are others on the page.
DDC... if possible, please pst a picture of the position of the mount on the wall. Ours came with a mount outside, under the awning.
Old 04-17-2012, 07:42 PM   #8
DDC
DDC's Avatar
Schrederman I have not figured out how to post pics here yet, if your 264 has the pull down tv look behind it and you will see the mount you can take the tv outside and it will slide onto the exterior mount.
Old 04-17-2012, 07:50 PM   #9
Our 12 Flagstaff 8528RKWS has a pocket door for the bath and the wall it slides in must have a backer board as there was a label saying to mount tv on this wall, which the dealer did. I think I would try to remove the door and look inside. With a little ingenuity, you could probably add a backer board and hang a tv on the wall like you want.
Old 04-19-2012, 12:35 PM   #10
bob213's Avatar
If you press above the co ax connection on the wall you will find a section of the wall about 10 X 10 that is solid. The rest of the wall feels soft. That is where the mount is intended to be placed.
bob213 is offline   Reply With Quote
Old 04-20-2012, 10:48 PM   #11
I ordered mine today... I'll post pics when I can.
Jack
Old 04-21-2012, 07:06 PM   #12
yep! you're right! Got it!
Thanks - Rick
Old 04-22-2012, 12:55 PM   #13
Tv mount
Our dealer mounted in right on the trim strip, which is where he said the best support was.
Dean517 is offline   Reply With Quote
Old 04-26-2012, 09:04 AM   #14
I got mine yesterday. It fit my TV perfectly. It's identical to the others in the trailer so I can move my TVs around if I want. I'll be screwing the mount to the bedroom wall this evening. I'll post a pic or two if I get it done...
Old 04-26-2012, 03:58 PM   #15
so... schrederman, what company did you order your's from? Do they have a web site?
Old 04-26-2012, 08:54 PM   #16
Local dealer gave me a catalog, and ordered the part for me.
Old 05-14-2012, 09:10 PM   #17
If you are having trouble finding a mount of the same type as the other ones in the camper, they are available from Jensen Direct. JENSEN LCD TV Mounts - The Best RV TV mount
You can even buy just the wall mount like
outside. You can find the exact same mount with the RCA brand on it by googling the model #.
Rick
Old 05-24-2012, 07:26 PM   #18
bob213's Avatar
How long of screws can you use when mounting the bracket? With my luck they'll be sticking out of my shower wall!
Old 05-25-2012, 08:29 PM   #19
I was lucky. The shower walls are only attached on the edges, so there's enough give that the screws didn't go through. I ended up moving it a little closer (actually tried to hit it) to the off set made by pocket door. I would try to shorten the screws that come with it a little, expecially if you are installing a smaller tv. No matter what you do, there's really not enough room between the bed and the wall, so the the tv makes the pathway crowded. I can see myself whacking my head on it in the middle of the night.
Old 05-25-2012, 09:01 PM   #20
bob213's Avatar
How big of TV did you mount? Can you post the description of the mount you ended up with please.
bed, tv mount
