Old 12-04-2007, 09:33 PM   #1
gregm59's Avatar
SV291 slideout
Hi, Does anyone have any info on manually closing the slideout in an SV291? We just upgraded to a new '07 model and when we were looking and asked the salesman, he said all newer ones had a way to manually close the slide, I guess like a hand crank or something. When we picked it up and were doing the walkthru with the tech, he said he didn't think the SV291 had a manual crank and if it did it would most likely be behind the sofa. Since the plate in front of the sofa is screwed on, I really would like to get a definite answer before I need to tear into the sofa. I couldn't find anything on the forest river website and there isn't a contact number there, either, so I guess another question is "Does anyone have a contact number for them"? BTW I asked in the RV.NET forum and was directed here.
gregm59 is offline   Reply With Quote
Old 12-04-2007, 09:57 PM   #2
MRimmer's Avatar
I have a good number but sorry to say its on my home machine and I wont be back home until Friday.
Wish I could help more and If you dont get a number before Friday I will post what I have as current.
Mike
MRimmer is offline   Reply With Quote
Old 12-05-2007, 07:38 AM   #3
first to FRF!
my manual overide for the slide is under the trailer
as I have the corrugated underbelly I had to do some searching for it but once I found it I made a cutout so I could access it should it ever become necessary. mine is a small gear box about 3/4 of the way away from the side the slide is on and located next to the front "arm". sorry I don't have pics
there is no crank on mine but it can be turned using a 3/8 socket extension
greg
aintgotnun is offline   Reply With Quote
Old 12-05-2007, 12:27 PM   #4
gregm59's Avatar
Thanks. I have the enclosed underbelly, but I don't know if it corrugated. Also, will a cutout mess up being able to heat the underbelly?
Old 12-05-2007, 02:25 PM   #5
Bama PrimeTime's Avatar
I also have a 2007 SV291. When we ask about a manual over ride, our salesman and service tech both told us that it would take two adults ,but you just push it closed. I hope we never have to find out if that's true!
John
Ted
Bama PrimeTime is offline   Reply With Quote
Old 12-05-2007, 07:19 PM   #6
gregm59's Avatar
Thanks, I also got that advice on the RV.NET forum. I too hope never to find out, but with my luck I probably will. If so, I'll let everyone know...
surveyor
