Old 09-04-2013, 07:19 AM   #11
yeah I am an electronics guy, I can troubleshoot. I was just looking for the answer saying I was stupid and the switch is in a cabinet or something
crazyliver is offline   Reply With Quote
Old 09-04-2013, 07:21 AM   #12
TURBS's Avatar
Both my trailers "flagstaff" and "palomino" had scare lights that had to be switched on manually.
On the far right you can see the switches.
Ods scare. "Opposite door side"
Ds scare "door side"
Only scare light I've seen with motion detection was old coots add on scare light with motion detection.
Old 09-04-2013, 07:23 AM   #13
TURBS's Avatar
This one.
Old 09-04-2013, 07:28 AM   #14
Attachment 39224
I do not have a switch panel like that. The 2 slides are separate buttons, and the other separate switch is the outside curbside light. Those 3 switches are on the upper cabinet above the sink, right by the door.
The water heater switch is on the cabinet below the sink, the water pump switch and black/grey water levels control is in the bathroom.
Old 09-04-2013, 08:13 AM   #15
If it makes you feel better our unit has (1) scare light on each side and we (Never)use them! I (Gutted) the one on the Door side and used it for a weatherproof area to mount the Box for (LED Awning Lights) and the switch is on a Panel at the door. Youroo!!
Old 09-04-2013, 08:50 AM   #16
This is the new scare light use! Youroo!!
Old 09-04-2013, 09:13 AM   #17
New Scare light,that we use! Youroo!!
Old 09-04-2013, 09:30 AM   #18
TURBS's Avatar
Bored today?
Old 09-04-2013, 09:43 AM   #19
Bored today?
17,861 and YOU ask me if Iam Bored? Youroo!!
Old 09-04-2013, 02:46 PM   #20
MOD Guy's Avatar
OP, I am 99.9% sure this is not a factory light (scare, spot, whatever you want to call it). It would have been something the previous owner added. What is directly behind the light on the inside? They had to pull power from somplace, and chances are the switch is close to that source.
I added a exterior switched light (swithc on the light housing) on the hookup/road side of my unit for night time setup.
Let us know where you find the switch!
Chuck Roder & Family
'07 Surveyor SV-235RS & '16 Chevy Silverado 2500HD (Gas) Crew Cab
High Springs, FL.
MOD Guy is offline   Reply With Quote
light
