Old 09-04-2017, 04:35 PM   #1
Tank Capacities
Can someone please tell me the black water and gray water tank capacities in my 2015 FR Surveyor model #201RBS. The manual is zero help.
Alan Sherman is offline   Reply With Quote
Old 09-04-2017, 04:40 PM   #2
30 gal Black, 40 gal Grey.
Google is your friend
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
TitanMike is offline   Reply With Quote
Old 09-04-2017, 04:46 PM   #3
Google wasn't even my friend for this[emoji81] thank you.
Old 09-14-2017, 07:30 PM   #4
This brings up another question. My Black & gray tanks are also 30 & 40 and my fresh water tank is 46 gallons. Is this 40 plus the 6 gallon hot water tank? The sensor lights on the gray tank say that the gray is full long before the FW tank is half empty, so I found early on that they are not very accurate.
I thought about filling the FW and draining it into the gray to see if it would all fit but not sure what would happen if it doesn't. It seems that it would just start to fill the bathtub from the drain, is that correct?
EddieL is offline   Reply With Quote
Old 09-14-2017, 08:49 PM   #5
Pokateps
I saw a thread yesterday about fresh water capacity. My 2016 micro lite 23fb. Says it has 46 gallon fresh water.
Today I climbed under my camper and measured the tank. 54" x 28" x 6". This works out to 39 gallon capacity using the outside dimensions
Then the fill and bent tubes enter the on the end and are about 1/2 to 3/4 of an in h from the top of the tank. So I would say I might be able to get about 36 gallons in it plus the 6 gallon hot water tank. I'd call that stretching the truth.
pokateps is offline   Reply With Quote
Old 09-14-2017, 08:57 PM   #6
Eddie,
Yes, it would be a 40 gallon tank if it is listed as 46.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
tank
