Unless you plan on not using the rear rack, it's a mistake to move the rear tire there.
My TT has the spare mounted to the rear rack BUT the rack is supposedly rated to be used with the spare mounted. The spare eats up about 35-40% of the rack weight rating. HOWEVER, no way can I get out my driveway with that spare not dragging significantly if the rack is down. Unfortunately, even if I remove the spare, the welded on tire holder bracket would still drag!
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 200W CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
