Old 08-01-2019, 04:03 PM   #1
johncarm84's Avatar
Tire pressure
Newbie question. I just purchased new Goodyear endurance tires for my 201RBS, max psi 65. The side of the trailer states less. Which should I obey? On previous tires I inflated slightly less than noted on side of trailer to account for increased temperature.
johncarm84 is offline   Reply With Quote
Old 08-01-2019, 04:10 PM   #2
DieselDrax's Avatar
Ah, another tire pressure thread. Please try the search function as this has been discussed countless times on here, even for those very tires (Which I also use). Be prepared to get every answer in the book now, from follow the placard, to run the sidewall PSI, so use the load/inflation chart from Goodyear based on the max load the tires will see (generally trailer GVWR or GVWR minus 10%).
You likely went from LRC to LRD (50psi to 65psi max load psi on the tire), the sticker probably says 50psi? The inflation chart will tell you 50psi with the new tires is sufficient. Or you can run more pressure if you want. There are multiple acceptable answers that wont result in carnage or catastrophic failure, so my answer would be...
"Anything between 50 and 65psi cold should be just fine. Tire pressure doesn't require precision, it just requires that you have sufficient pressure for the load and isn't overinflated."
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
DieselDrax is offline   Reply With Quote
Old 08-01-2019, 05:34 PM   #3
And don't ever compensate for increase in pressure as temp goes up. The pressure specs already take that into account.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 08-01-2019, 06:58 PM   #4
johncarm84's Avatar
Sorry for bringing up again. Attempted to search “tire pressure” and about 27 threads came up. Got a headache just trying to read some to see if it pertains to my question. Is there a different place to find the answer? Again not trying to beat a dead horse. Thanks for your reply.
Old 08-01-2019, 07:24 PM   #5
DieselDrax's Avatar
Not really a better place, most of those threads give people headaches because so many people think there's only one correct answer and the threads just go downhill.
The Endurance inflation tables can be downloaded here...
https://www.goodyearrvtires.com/pdfs/rv_inflation.pdf
If your trailer's GVWR is something like 5,425LB then you could see 1,350LB per tire (5425 / 4). I'm not subtracting for tongue weight here so this is a conservative, high number.
Find your tire size on the table linked above, you'll see that 25-30psi is TECHNICALLY the minimum PSI needed to carry the load of that GVWR at the tire's rated speed. Of course, that would be a bad idea and the trailer would track horribly.
Going back to my previous post suggesting anything between the trailer pressure and the max-load pressure of 65PSI for the tires you'll see that the load for the tire pressure listed on the trailer is likely well above the minimum pressure needed for that load.
Which means you likely don't have to change your tire pressure at all. Or you can increase it and see if it helps with stability or fuel economy at all.
There's no single correct answer, just what you find works the best and meets or exceeds the load the tires will see but isn't overinflated. Tire pressure should be checked when tires are "cold" (first thing in the morning before being driven on and before the sun heats them up). The pressure will increase as the tires warm up, this is normal and already factored into the tire pressures as well as the max-load tire pressure, meaning a tire at 65psi cold will be higher than 65psi after it starts rolling down the road and this is already factored into things.
2013 Shamrock 21SS
Old 08-01-2019, 08:16 PM   #6
Tire pressure carries the weight...not the structure of the tire. Higher load range tires have more robust structures to take higher pressures....to carry heavier loads. If you want the benefit of higher load range capacity with higher load range tires, inflate them to the max pressure on the sidewall. Otherwise you gain no benefit. Skip the million opinions on these forums and go to the source of accurate information:
RV Tire Safety
Roger Marble has 40 years experience as a tire design engineer. His blog has the best info available if you want to educate yourself on tires.
__________________________________________
2014 Spartan 1032
2015 GMC 3500HD Denali 4WD/Duramax
RockyMtnMarty is offline   Reply With Quote
Old 08-01-2019, 08:29 PM   #7
DieselDrax's Avatar
RV Tire Safety
Patently false to say higher load range tires have no benefit if not run at the higher pressures they allow, but whatever. Here we go...
I'm out before the drama begins. I warned the OP this would happen, too.
2013 Shamrock 21SS
Old 08-01-2019, 08:42 PM   #8
Get yourself better educated...
Old 08-01-2019, 09:18 PM   #9
And evidently some folks can read every word of every expert and still not be educated.
Old 08-02-2019, 12:54 AM   #10
And even he says to use the tables.
RV Tire Safety
pressure, tire
