10-20-2016, 08:27 AM
Tongue jack interferes with tail gate
Hello,
Just bought a 2017 Surveyor 243RBS. Like the layout allot.
I was annoyed that the power tongue jack interferes with fully opening the tail gate. I called Lippert, the mfg and they had no solution, go figure.
I solved the problem easily and have included a you-tube video link that details how to do it.
I hope Lippert views this video and make the fix themselves on all their power tongue jacks.
Its worth the time folks!
Hope it helps you.
Joe
10-20-2016, 08:43 AM
Welcome to the forum its a great place to get your questions answered. I watched your video and it is a good fix given the truck you use. this might be something I'll consider once my warranty time is over.
Retired Navy
2016 Flagstaff 26 FKWS
10-20-2016, 08:59 AM
Great solution but the issue isn't with the jack, its with the distance between the jack and the hitch on the trailer. Not sure how LCI could "fix" the jack to overcome this issue.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
10-20-2016, 09:07 AM
Get a longer shank.
10-20-2016, 11:51 AM
Not too bad, but you didn't show us how you actually rotated the head, nor did you show it hooked up and the tailgate down.
Even a before and after rotation shots would be nice.
Gotta go campin!
10-20-2016, 11:56 AM
I think this problem is common. I can't open my tailgate fully either and I have a different camper & electric tongue jack.
On one brand of trucks the tailgate can open normally like all tailgated do or it could be opened like a regular door. When I saw that TV commercial I wonder if it would make a different when hitched up or would it have the same outcome.
10-20-2016, 11:58 AM
Originally Posted by 325BH
Get a longer shank.
Works every time.
10-20-2016, 12:08 PM
Clears tailgate when open...
Hello,
The head was facing forward, now its rotated 90 deg to the right, I'm sure you can visualize that. The tailgate clears with a couple inches to spare. Reason its to the right is not enough harness length to face left. I did not do the video till I was done, would have been better if I did it in process...oh well. If you do this upgrade then make an in process video...
10-20-2016, 12:22 PM
Canadian Member
I solved my problem, inadvertently, with a new pickup. I decided I had to upgrade to the 2016 F250 because I was way overweight with my 7300# TT connected to my 2009 F150 with all 5 of us onboard. I discovered the first time I hooked up the TT to the new F250 that the receiver on the F250 is positioned further back on the frame compared to the F150 and it puts my Equal-i-zer hitch head further away from the tailgate, so now the tailgate doesn't hit my Husky HB4500 electric jack.
The truck upgrade wasn't free but this was a pleasant bonus.
10-20-2016, 01:05 PM
Thank You!
Thank you!
I was going to look into a longer shank but now I may not have to.
Craig & Nancy
2016 Coachmen Freedom Express 257-BHS
2007 Ford F250 Super Duty Lariat Turbo Diesel
10-20-2016, 03:39 PM
+1 for the longer shank for your hitch. With the tailgate down, I have ~4" between the tailgate and the power jack. I have even towed my trailer with the tailgate down (when I had the Goldwing in the bed of the truck).
Catalina 333RETS
Keystone Outback 23RS
Silverado 2500HD
Goldwing 1800GL
10-20-2016, 03:46 PM
It's a lot easier than shown in the video. Simply support the Aframe tongue, so that you can retract the jack off the ground (or leave it attached to the truck hitch), loosen and remove the three mounting bolts that attach the jack to the a-frame and rotate the entire jack 90 degrees in whichever direction you wish. The mounting holes are designed (usually) to be equidistant from each other so that the jack can be installed "sideways".
...VTX-Al
10-20-2016, 05:37 PM
Exactly! I have the same issue. It has nothing to do with the jack but everything to do with the length of the bar on your hitch where it enters the receiver.
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags. 2011 28RKS Wildcat. Yamaha 3000iseb Gen.
2014 57 nights.2015 116 nights .2016 96 nights .2017 72 nights. 2018 157 nights. 2019 52nights.2020/21 118 nights. 2022 115nights
10-20-2016, 09:00 PM
All I had to do on my Ultra Fab 3500 jack, was rotate the motor 180°.
Now I can drop the tailgate.
10-20-2016, 10:11 PM
Originally Posted by us2kids
Hello,
Hope it helps you.
Joe
Great post Joe. I have a Ram 1500 with the same problem. I spent 80 days on the road, what a pain in the *****. Before my next
Trip I will be doing your fix. Thanks again, d Espo
10-20-2016, 10:18 PM
I have the same problem with an SUV lift-gate. I think if you look at the base of his jack you will see it is not symmetrical so a simple 90 degree rotation won't work. I have the same type of base on my jack.
2004 ALiner Expedition
2008 Trailmanor 2330
2016 Rockwood Mini Lite 2304 ks
2020 Lance 2075
2008 Lincoln Navigator 5.4 V-8 with Tow Package
2015 Ford Expedition Ecoboost with Heavy Duty Tow Package
10-20-2016, 11:50 PM
Hello,
Hope it helps you.
Joe
I have a longer L shape bracket on my Equalizer hitch and it allows for easy use of any tail gate on pickups or lift gates on SUV's such GMC Yukon XL, same as a Chevy Suburban.....
10-21-2016, 04:03 PM
Cool idea. I tried rotating the entire unit, but the holes don't line up anyway but forward. I miss by about 2". I'll have to take it apart and check this out. Thanks.
2015 FR Classic 625D
2011 Toyota Sienna XLE
10-21-2016, 05:03 PM
I also tried rotating the whole unit with the same problem.
So rotating the motor 180° worked perfectly.
11-01-2016, 10:58 AM
Before upgrading to a truck, we towed with a Suburban and had the same issue. After breaking the LCI jack, I bought a Bull Dog 3500 to replace it and what I discovered is the Bull Dog is smaller, and thus my tailgate would open.
2016 Rockwood 2702WS
2016 Chevy 2500HD Duramax 4x4 High Country
