11-25-2019, 09:16 PM
Tool kit...
New 287bhss owner and am looking to put together a "camper toolbox". Anything I should make sure is included? All input is appreciated 🤙
11-25-2019, 09:48 PM
Lug wrench.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
11-26-2019, 08:03 AM
Trailer Park Supervisor
Yes, lug wrench #1! For plumbing emergencies, a PEX tubing cutter, PEX crimper, and a handful of clamps. Or you might get by temporarily with some worm gear clamps and a screwdriver. Mainly for braided hoses, PEX will probably never leak. I was lucky enough to discover my issues at home, but it could easily have been on the road.
A cheap multimeter and spare 12v fuses for whatever sizes you have in your unit.
Yes, I drink the water!
11-26-2019, 08:07 AM
Critical, from Lowe’s.
A $4.95 square tip screwdriver!
And a Voltmeter.
11-26-2019, 08:14 AM
I Agree with the others plus a socket for water heater anode, Teflon tape, Zip Ties, Duct Tape, Tire gauge, also normal tool box contents.
Mark & Heather
Mountain Falls, VA
2019 Salem FSX 179DBK
11-28-2019, 12:34 PM
Jack for the TT to go with that lug wrench.
Folding shovel. I've got the solid fold down MorRyde steps and a side sloped campsite can cause the door to bind on the steps.
Battery powered drill with drill bits and screwdriver/socket bit set. Get the socket bit for your stabilizers, much easier than hand cranking. $5 on Amazon.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
11-28-2019, 12:51 PM
#1 socket,extension and breaker bar to change a tire. Make sure the socket fits over the nut, aluminum wheels may require a thin wall socket (6point). Also members here have reported the spare is bolted to the unit with a different size socket than is used to take off the tire from the axle.
#2 socket 1-1/16 for the water heater, can use the same bar and extension as used for the tires.
#3 common hand tools, cordless drill and a complete set of bits including extension and the bit to put down the stabilizers. External battery and or battery charger. Tire gauge.
#4 assorted screws, nuts, wire tape, Teflon tape, fuses, bulbs if not LED, some wire and an a few wire ends.
#5 some way to jack up the camper to change the tire, can be a bottle jack, the tv jack or a ramp.
I carry way more on long trips than when going to a local campground. Jay
Old Rv 2016 Rockwood 2504s.
Old TV: 2014 Silverado 1500 double cab.
New RV 2020 Jayco 24RBS
New TV 2020 2500HD gas.
11-28-2019, 01:44 PM
Coach
Don't forget a razor knife.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
11-28-2019, 01:47 PM
I can't list all the 'tools' I carry. The issue now is that I have so many, in every nook and cranny, that I can't remember where the square tipped bits are, or where the small crowbar is, etc. etc. etc.
FROG AR-0019-242
11-28-2019, 01:54 PM
Coach
Yeah, we're those folks at the campground too. But as long as I know it's in there, I can fix it. At least after I find the tool I need.
11-28-2019, 03:29 PM
Torque wrench for lug nuts
2018 Flagstaff Super Lite 29RKWS
2015 F 150 max tow
Where ever you go there you are
11-28-2019, 04:39 PM
Great input. I appreciate everyone's help
11-28-2019, 05:18 PM
Depends on your skill level.
I carry things others might not like torches, soldering iron, PEX tools, come along, chain & binders, torque wrench, hacksaw, snap ring pliers, drift punches, tin snips, Torx/Allen wrenches, etc.
There have been several past discussions on this topic and eventually, every tool imaginable gets mentioned. No need to carry them if you can't use them.
11-28-2019, 05:50 PM
Torque wrench, large multi socket/wrench combo kit from Lowes, spare alternator, spare fluids, oil, trans fluid, hose for a possible trans cooler line blow out, multi meter, folding triangle and flare kit, air compressor, and what ever else I can't think of, I figure if I have it I'll never need it!
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
11-28-2019, 08:45 PM
Before you purchase a lug wrench, make sure that it will work with your wheels. My TT wheels are shaped so that I have not found a regular lug wrench that will fit into the area where the lug nuts seat. I have to use a deep socket and 25" breaker bar to get the lugs off. My truck also needs deep well sockets to get the lugs off. The bar that came with the truck is about 15" long and the lug nuts are torqued to 150 ft/lb so the 251" bar gives me enough power to break the lugs free. A torque wrench is also a requirement for me.
11-28-2019, 09:10 PM
A credit card with a high limit!
Dennis, Linda, and Scout the Dog (RIP)
2015 Mesa Ridge 347 RES
Curt A20
2020 Ram 3500 Dually with HD Cummins TD
11-28-2019, 09:27 PM
Everybody keeps telling me that and I'm afraid wife will hear. That is her one job, cranking down the stabilizers. Makes her feel useful. Can't take it away from her, lol.
11-28-2019, 09:53 PM
Yes... I suppose a 20.9 foot bar would break the lug nuts free! [emoji23][emoji23][emoji23]
11-30-2019, 11:46 AM
I just picked up a great full tool kit on sale at Harbor Freight for $30. It's going in the truck.
11-30-2019, 12:09 PM
Wait til you start cracking sockets with little force!
2015 F 150 max tow
