Old 05-02-2016, 06:33 AM   #1
Question Tundra with Equilizer Hitch CAT scale #
Hello -
Do these numbers seem right:
Vehicle: 2014 Tundra SR5 (2wd)
Empty: (one driver 3/4 tank gas)
Steer axle: 3000
Drive Axle: 2460
Gross: 5460
Same Vehicle (driver & pax, 3/4 gas)with 29' Surveyor (lp, battery, 10gal water - quoted empty 5700lbs))
Steer Axle: 3040
Drive Axle: 3560
Trailer Axle: 5420
Gross: 12,020
The truck fenders move a bit when loaded to tow, but all are within 1/2"of each other.
Truck sits level, trailer too.
Is the hitch set right?
Retired U.S. Coast Guard Mustang
Presently a librarian @ Duke
2016251RKS is offline   Reply With Quote
Old 05-02-2016, 07:04 PM   #2
Coolharts's Avatar
Sounds like truck and trailer are right, are you using weight distribution? On second thought the front truck axle when loaded seems light.
2017 Surveyor 33RETS with Residential Refrigerator and Inverter
2005 Ford Excursion 6.0L 2WD
Nights Camped 2016 27, 2017 29
Nights Camped 2018 4 Scheduled 25 (so Far)
Coolharts is offline   Reply With Quote
Old 05-02-2016, 07:24 PM   #3
I'm using the equalizer with the 10k# bars. I thought the front may be a bit light, but will re-weigh with the entire pkg ready for a camp experience. THe front steering wasn't floating and the truck / trailer are level. . . .
Old 05-02-2016, 07:34 PM   #4
Coolharts's Avatar
I would try tightening the front some and see how it drives, a little trial and error plus when you load the truck and camper with gear you will have more weight.
Old 05-02-2016, 08:50 PM   #5
You are already over the original front axle weight by 40 lbs. Do not tighten it anymore.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 05-02-2016, 09:15 PM   #6
Canadian Member
itat's Avatar
If you have the Equalizer instruction manual, follow it to get the front fender at least half way back down from when it's loaded without the bars on. The closer to original height the better. Then make sure the bars are parallel to the a frame.
Finally, go to the CAT scale and do 3 weighs. Go to this website for weighing instructions and to do the calculations. Actual Weights - Travel Trailer/Bumper Pull Weights from CAT Scales - Towing Planner
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
cat, hitch, tundra
