Old 06-30-2017, 12:19 PM   #1
bob213's Avatar
TV Mount in SV264RKS
Our tv pulls down from behind the upper cabinets above the dinette. Does anyone know what kind of mount this is or how to release the tv from it?
You can avoid reality, but you cannot avoid the consequences of avoiding reality Ayn Rand
bob213 is offline   Reply With Quote
Old 07-01-2017, 12:22 PM   #2
bob213's Avatar
Come on. I can't be the only one with this mount!
Old 07-01-2017, 10:13 PM   #3
schrederman's Avatar
I had a '12 SV 264 which is the same floor plan. There's a tapered fixture that the TV is screwed to. In the middle at the top is a clip to keep it from bouncing up and off. I can't remember if you have to push the clip toward or away from the TV... but with the TV pulled all the way down, you can release the clip and lift it off... To put it back on just position it correctly and let it drop onto the taper and the clip will engage. My TT came with an outside TV mount that was the same as the taper inside. I could move it between locations, but I never did. I just bought another small TV and another tapered mount.
Enjoy!
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
Old 07-02-2017, 12:34 AM   #4
bob213's Avatar
Thanks for responding.
My TV slides down from behind the upper cabinets (hidden when not in use) and slides on what looks like two drawer slides. Are you saying that the TV is attached with the bracket in the following picture? I have this bracket in the bedroom but couldn't see it on the dinette TV. I'll have to look again. Thank you again!
Old 07-04-2017, 03:37 PM   #5
Yes, that's made onto the sliding mount. Enjoy!
mount, tv mount
