Old 08-16-2010, 04:02 PM   #1
cullivoe's Avatar
Using gas only for WH on 235RS
Hi,
How can I get the water heater to use only gas and not electricity? This would help when using our generator. Does it go to electric automatically when it's plugged in? Is the switch by the sink the gas control? Is the switch on the WH the electric control?
cullivoe is offline   Reply With Quote
Old 08-16-2010, 04:51 PM   #2
milzat's Avatar
Behind the outside access panel, in the bottom left there is a small black switch. This switch is to control the electrical heating element. Switch it to OFF and it will only work on GAS.
milzat is offline   Reply With Quote
Old 08-16-2010, 04:53 PM   #3
milzat's Avatar
Yes, the switch by the sink is to control the GAS solenoid and igniter.
Questions & Answers
Old 08-16-2010, 05:02 PM   #4
cullivoe's Avatar
Thanks for the clarification...We burned out one electrical element, and don't want to do that again.
Cullivoe
'07 Forest River Surveyor 235RS
Old 08-16-2010, 05:15 PM   #5
milzat's Avatar
As long as there is water present in the water heater tank, the element won't burn. You have to remember, when using the electric element to heat water, make sure the tank is full before switching it ON. Also, when you break camp, turn the switch OFF before disconnecting from a water supply.
BTW, the element can be purchased at almost any hardware store. They're fairly inexpensive and easy to replace.
Old 08-16-2010, 07:35 PM   #6
acadianbob's Avatar
The switch is a black rocker switcher relatively well hidden in the bottom left hand corner.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 08-16-2010, 09:05 PM   #7
Good news guy's Avatar
The switch should have a safety pin so you can't turn it on by accident. When you are done with the electric I would re pin it off.
2007 FOREST RIVER SURVEYOR 235RS
Good news guy is offline   Reply With Quote
Old 08-17-2010, 07:25 AM   #8
KyDan's Avatar
My trailer has a circuit breaker in the power panel for the
electric side of the HWH. It's much easier for me to flip off
the inside breaker than to go outside and open the access door.
Either one will shut off the electric heating element.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 08-17-2010, 08:05 AM   #9
MtnGuy's Avatar
My water heater breaker also power the fridge.
Old 08-17-2010, 08:10 AM   #10
milzat's Avatar
Yes, it is handy, but a breaker isn't meant to be used as a switch. It WILL shorten it's life.
While circuit breakers can be legitimately and safely used as switches, the frequency and duration of such use is limited. Routinely circuit breakers are manually operated for service-maintenance and repair type activities. With the preceding enhancing our understanding, we can say that circuit breakers can legitimately be used as switches; generally they are not intended for prolonged repetitive manual breaking and making type control of electrical energy utilization equipment.
When a circuit breaker is designed to also be routinely used as an on-off switch, they are marked SWD, for switch duty.
If you must, install a ON-OFF switch somewhere within the trailer. This is a very SIMPLE process. It can be mounted at easy reach and much easier than stooping down at the converter box to flip a "not intended for switch-use" breaker.
Thank you,
235rs, surveyor
