Old 09-30-2012, 09:39 PM   #1
Water heater bypass location? (Solved)
We have an sp-280 and I can't seem to find the water heater bypass. The brochure states its a standard option. Anyone know where it's located?
jeerme is offline   Reply With Quote
Old 09-30-2012, 10:20 PM   #2
should be directly behind your hot water heater on the inside. You may need to remove a panel to find it.
Flagstaff 8528 ckss fiver
2008 Ford f350 dually 4x4 desiel
racerx is offline   Reply With Quote
Old 09-30-2012, 10:23 PM   #3
acadianbob's Avatar
Often under a dinette seat or something similar. Locate the heater externally and then visualize where that is on the inside. You may have to unscrew and remove a panel as previously posted.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 10-01-2012, 05:26 AM   #4
what the two above posted..
yep - snooping around my newly acquired tt I removed the plywood panel that is under our lower bunk mattress and behind the water heater - all the water lines and valves there, including all the trash left by the workers at FR (all clean now and also found a dime).....Bill
Whisky is offline   Reply With Quote
Old 10-01-2012, 07:29 AM   #5
MtnGuy's Avatar
Check under the forward, bottom dinette seat cushion.
Old 10-02-2012, 08:46 PM   #6
Found it tonight. Underneath the back bunk there are four screws and the board lifts up and it's right there. Thanks for the help!
Old 10-02-2012, 10:25 PM   #7
Fire Instructor's Avatar
I've removed all of those silly panels that FR installed to "hide" various components. Made them much more accessible for monitoring and servicing, plus opened up a considerable amount of storage space for small, not often used items.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
