Old 08-08-2017, 01:14 AM   #1
Water heater question...
We have a Sport 220... 2014...with a 6 gal. Water heater that just quit making hot water... It's warm at best... Is there a adjustment or just replace the element... Or can you replace it?
Any help would be greatly appreciated...
PS I've tried it with gas and elec... Same resultes....
It's like it won't stay on long enough...
Steve & Brigitte
North Eastern Oregon
The Right Side of the State...
_______________________
2013 Surveyor Sport SP220
2014 Toyota Tundra Dbl
samsberr is offline   Reply With Quote
Old 08-08-2017, 05:53 AM   #2
DouglasReid's Avatar
Lets start with the basics.
How have you been operating it before, Electric or Propane. It WILL operate on both at once.
Is the switch inside the camper on? (propane)
Are the propane bottles on?
Is the switch behind the outer WH door on? (Electric)
Is the circuit breaker on?(Electric)
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is online now   Reply With Quote
Old 08-08-2017, 06:08 AM   #3
Did someone fiddle with the bypass? Also, leaving the outside shower on at the valve and off at the head can cause a loop that causes warm water (from what I have read on here that is).
Marty
2016 Rockwood 2703WS Sapphire
2016 F250 SD 6.2L
Martsing is offline   Reply With Quote
Old 08-08-2017, 09:56 AM   #4
Thanks for the input... Yes all switches and valves are on... I run it with gas and elec turned on...
Steve & Brigitte
Old 08-08-2017, 09:59 AM   #5
How did it happen that you found it only giving warm not hot water
Old 08-08-2017, 10:41 AM   #6
It worked great last month, but this trip it was only luke warm...
The cold water is very cold compared to the hot side... So it's working a little bit...
Steve & Brigitte
Old 08-08-2017, 10:49 AM   #7
OK,
Turn off the electric switch inside the water heater door outside. This will kill the electric heating element.
Thrn off the switch inside, this will turn off the gas heating. I assume it is a DSI (lights itself without a pilot)
Turn on the burners of your stove til they light, then turn them off. (this will purge any air in your gas lines and insure gas is reaching your WH)
Then have your wife turn on the switch inside as you stand outside at the WH. See if you hear a clicking sound as the gas burner tries to light itself.
Tell us what you see and hear with the door removed. It should try three times or so if it is unsuccessful. Does it light and go out, does it not light at all, does the gas flow, etc.
Old 08-08-2017, 11:03 AM   #8
Thanks much... I'll go after it tonight after work... I'll let you know...
Steve & Brigitte
Old 08-08-2017, 11:04 AM   #9
PS... this is a DSI unit...
Steve & Brigitte
Old 08-08-2017, 11:22 AM   #10
If your cooktop will not light, close the gas valves, open the stove burner to let out the pressure an close the stove valve back off. Then very slowly open the gas bottle back on, just a small bit at a time. That Acme connector is designed to shut itself off if it detects a large change in flow (as if a leak had developed). Closing, and resetting it should solve the problem if that is the case. Then go back to lighting the stove and the procedure I outlined earlier.
What we aer doing is taking one thing at a time, your gas and electric WH systems are separate and no single item is common, except the bypass valves which someone mentioned earlier. Im assuming you did not move them since last month when the WH was working?
heater, water, water heater
