Old 09-30-2013, 11:51 AM   #1
Water heater- using elec and gas at same time
Can i use both the electric element and propane at the same time to decrease recovery time?
johndeerefarmer is offline   Reply With Quote
Old 09-30-2013, 11:54 AM   #2
Fulltime family RVer
Yes.
Old 09-30-2013, 11:55 AM   #3
tanddc's Avatar
I am not sure what heater you have but on my Suburban there is no problem using both at the same time. Speeds up recovery and saves on propane. Just be sure there is plenty of water in the tank when you turn on the switch (and be sure to turn it off when you are done for the trip). The electric elements only require seconds to burn out.
tanddc is offline   Reply With Quote
Old 09-30-2013, 12:01 PM   #4
Ford Idaho's Avatar
I thought gas was faster in regards to recovery time.
I would not use both at the same time.
Old 09-30-2013, 12:09 PM   #5
tanddc's Avatar
Gas is faster than electric but both are faster than just one. Plus it saves you on propane. There is no reason I know of not to use both. If you forget and burn out your electric element, the gas will still work and it is an easy and fairly cheap fix
Old 09-30-2013, 12:16 PM   #6
Been using both at the same time on 9 different trailers since 1975 with no ill effects. They are made to use both at the same time, otherwise there would be an interlock to prevent it.
Old 09-30-2013, 12:19 PM   #7
Using both is fine. And as many have mentioned just make sure you always have water in it when on. Also keep in mind its on if you need to conserve power when running a generator or other high amp draw items on limited power.
~Andrew
99 F250 Super Cab Short Bed 7.3 Powerstroke
84 24' Yellowstone Camino (oldie)
http://rvpdi.com
Acableguy06 is offline   Reply With Quote
Old 09-30-2013, 12:24 PM   #8
EricInColorado's Avatar
Seems like one could just wait 5 minutes and it would recover pretty well on elec alone? Maybe you have 8 daughters that all need to shower?
Eric, Tara, and most of China
2013 Camping Nights: 2
2014 Camping nights: 31
TT 2014 Rockwood Roo 183
TV 2012 Nissan Armada
EricInColorado is offline   Reply With Quote
Old 09-30-2013, 12:34 PM   #9
Nope, just the 2 of us. Takes a lot longer on electric. Like the old sales pitch says, "Try it, you'll like it"
Old 09-30-2013, 12:58 PM   #10
bobcrowder's Avatar
Funny story about me and my water heater. I couldn't get it to heat up using electric early this camping season, so I just used gas for the first few trips. Then I got serious about getting it fixed. Thought I needed a new element, so I bought one and installed it. Still no hot water. So I got out my tester and found that I had no power to the element. Long story short. I had unpluged it while winterizing as a precaution against turning it on before filling it with water( it worked). Totally forgot about that plug in the closet. I think I'll unplug it again this year.
2012 F150 4x4 5.0
2011 Cherokee Grey Wolf 26bh
God Bless America
bobcrowder is offline   Reply With Quote
gas, heater, water, water heater
