Old 06-11-2015, 05:34 PM   #21
Mine was leaking there and the wooden box behind the outside panel was the problem. The caulk around that box that houses the fridge components had separated from the sidewall of the camper. Some new caulk fixed the problem. Mine only leaked when the wind would blow the rain in from that side. May want to check it.
2013 Coachmen Freedom Express 291 QBS
2013 Chevy Silverado 1500 Crew 4x4 5.3
Jandj1026 is offline   Reply With Quote
Old 06-11-2015, 05:42 PM   #22
Cyber Phrenologist
Radio's Avatar
Does it leak regardless whether the slide is in or out?
Does the slide have an awning?
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 06-11-2015, 05:42 PM   #23
Mowgli64's Avatar
We got ours back a couple weeks ago from getting leaks fixed. The dealer was able to pressurize the inside and then use soap to check for air leaking on the outside, takes a lot of the guess work out. I have not seen any leak since.
2015 Wildwood X-Lite 271RBXL
2013 Ford F150 Crewcab Ecoboost
Mowgli64 is offline   Reply With Quote
Old 06-12-2015, 11:01 AM   #24
Crockett's Avatar
2013 wrs30 water damage
this is a thread that may interest you...we covered the side vents
Crockett is offline   Reply With Quote
Old 06-12-2015, 12:14 PM   #25
I had a similar problem, the dealer ran a ridge of silicone caulk on the bottom of the opening inside the side vent.
Good luck
tomrob1161 is offline   Reply With Quote
Old 06-12-2015, 12:17 PM   #26
Roof vents get broken easily check it out. Easily replaced
Harkerr is offline   Reply With Quote
Old 06-12-2015, 12:18 PM   #27
TURBS's Avatar
Fridge is in the slide out, there is no roof vent.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 06-12-2015, 12:46 PM   #28
Thank you all for the feedback. We did run a ridge of silicone in each vent 2 weeks ago and it did not fix the issue. It leaks whether the slide is in or out- no awning on the slide. When the slide is in we can see that there is no moisture on the top of the slide.
Hopefully the dealer will be able to find the elusive leak and the damage won't be more extensive than we think. We were hoping to fix it on our own since they're saying it will take about 3 weeks. Keeping our fingers crossed that we'll have it back and ready to camp by 4th of July weekend!
FootRest is offline   Reply With Quote
Old 06-13-2015, 08:04 AM   #29
Good luck, my refrigerator side vent wasn't sealed properly, inside wall swelled. Dealer reinstalled the vent, wall appeared to dry out and return to normal. They also reseal(?) the roof vent. The floor was a little spongy for awhile, dealer said it should go away (ha, ha). This was the least of problems. Don't you just love the fact there is no RV lemon law!
DJsFolly
D. J. Schuler is offline   Reply With Quote
Old 08-17-2015, 11:38 AM   #30
I'm working on the same problem, I can't see if there is any solution here. Anyone got any ideas? I caulked around the refer vent, changed a cap on the roof vent for the toilet, but I still get leakage in the closet. Hasn't rained since and am having trouble finding the wet spot on the outside.
hepkess is offline   Reply With Quote
fridge, leak, water, water leak
