Old 10-21-2018, 06:23 PM   #1
Water ? Pouring from underskin
Picture Attached-Shakedown Cruise this weekend. Kept all line closed for gray and black water till getting ready to hook to leave and water (looked like had soap bubbles and did not smell) started pouring from underskin of 251rks. Husband said he thinks no gray or little gray came through hose (hooked with Y connector). It seems obvious there is an issue. We are slated to leave for mountains in 2 days and not sure if this is a deal breaker for campout and take to dealer OR keep all tanks closed till last day and deal with gray water in underbelly again then take to dealer for repair? Anyone experience this before or have input?
Angieburns is offline   Reply With Quote
Old 10-21-2018, 06:39 PM   #2
Possible to drop the belly and take a peek inside? Might give you some insight on whether it's an easy fix that you can do right then and there or a more complicated issue that the dealer might need to tackle. I myself will try to tackle anything within my means before I take it to a dealer.
Also looks like an access panel you could use to take a peek too.
Good Luck!
2018 Rockwood 8244BS
2006 F250 6 speed
[SIGPIC]
kamper00 is offline   Reply With Quote
Old 10-21-2018, 06:41 PM   #3
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
I would not go camping with this issue looming over my head. If you have a responsive dealer with an outstanding service department then let them fix it tomorrow - yes, there are still a few good ones out there. If not, let your husband pull the coroplast down and have him look for a glue joint that has come apart or something similar the gate valve and the sewer hose connector.The fix is probably simple, yet time consuming and messy but if the dealer would have done a proper PDI this would never have happened.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 10-21-2018, 06:59 PM   #4
If built like my FR product, the PVC pipe that goes into the gray and black tank is secured with just a hose clamp, not PVC. Maybe just a simple tighten might work that is if it is the connection between PVC pipe and the tanks.
2006 F250 6 speed
[SIGPIC]
Old 10-21-2018, 08:28 PM   #5
Looks like it was already opened up once before for inspection. Prob a bad connection, post pics of it opened up
cmysstailights is online now   Reply With Quote
Old 10-21-2018, 09:23 PM   #6
Thanks for your response. We are going to call dealer in the morning and try and get in ASAP since we don’t know how to properly remove the skin and not sure how that may effect warranty since it’s just a week old!
Old 10-21-2018, 09:38 PM   #7
bikendan's Avatar
Originally Posted by Angieburns View Post
Thanks for your response. We are going to call dealer in the morning and try and get in ASAP since we donít know how to properly remove the skin and not sure how that may effect warranty since itís just a week old!
Did they not have the water system pressurized for your PDI/walkthrough?
Equalizer WDH
Old 10-21-2018, 09:42 PM   #8
Iím not sure what that means?
The guy did a very good PDI I thought compared. We turned on water both cold and hot but there were no problems since we didnít attemp to drain that little bit out of tanks. Is there something Iím missing?
Old 10-21-2018, 10:02 PM   #9
bikendan's Avatar
Many dealers don't get the water system pressurized with water, for the walkthrough.
Then new owners leave, only to find that there's a leak issue.
Strange that it didn't leak at the dealer but started on your shakedown trip.
Equalizer WDH
Old 10-22-2018, 12:38 PM   #10
Water pouring from underskin
Had a similar problem with my 2014 Surveyor. It leaked after showers were taken. The drain at the shower was not tightened correctly. I took it back to the dealer who found the problem and fixed it.
Rmstack is online now   Reply With Quote
water
