Old 01-31-2019, 07:34 PM   #1
WV Rambler
kraushad's Avatar
Water Pump Access
Not that it is a huge problem to get to anyway, but I took some time to make accessing the water pump easier on my 287bhss.
The pump is located in the pass-through on the street side, and being a larger guy who has trouble climbing inside to get to the screws to remove the panel, I decided to simplify the amount of time I have to spend as a sardine.
I carefully removed the trim piece seen on the left of the first picture. It was originally attached to the stationary middle panel so that the removable panel had to slide behind it. I reattached it to the removable panel just so the trim piece would cover the gap. Then I took a piece of PVC molding and cut it to reveal a thumb-screw sort of retainer, that can rotate. Then I glued a piece of 1/2" square stock just inside of the hatch opening on the right hand side to hold that end of the panel in place. So the panel slides into the small gap between the hatch door frame and the existing frame and stays put without screws. Then the other end pushes back into place, and the thumb screw holds that end in. Tool-less removable/replaceable in seconds, and no more trying to get in there with a screwdriver to remove it.
REMOVABLE PANEL WITH PASSTHROUGH DRAWER PUSHED OUT OF THE WAY - 1/2" stock piece is glued between the frame and the panel on the far right of this picture out of view):
THUMBSCREW IN "LOCKED" POSITION
THUMBSCREW IN UNLOCKED POSITION
PANEL REMOVED AND SLID OUT OF WAY
Dirk
2018 Surveyor 287BHSS
2006 GMC Sierra 1500
kraushad is offline   Reply With Quote
Old 02-01-2019, 03:05 PM   #2
clarkbre's Avatar
Great idea and a very easy modification to make. It amazes me how much inspiration comes off this site to better our trailers. Thanks for sharing!
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
clarkbre is offline   Reply With Quote
Old 02-01-2019, 04:07 PM   #3
Fulltime family RVer
I love the thumbscrew idea!
Old 02-02-2019, 11:22 AM   #4
Indy500's Avatar
If I could you a thumbs up , I would ))
Indy500 is offline   Reply With Quote
Old 02-02-2019, 12:34 PM   #5
You could use one of these:
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
pump, water, water pump
