Old 10-29-2014, 03:34 PM   #1
Water Pump Location
Looking to winterize a Surveyor Cadet 226 RBDS.
Was going to avoid adding antifreeze to fresh water tank.
But was unable to locate the water pump.
Any help appreciated.
Dick
rstowe is offline   Reply With Quote
Old 10-29-2014, 04:14 PM   #2
offroad's Avatar
Put some fresh water in the tank, turn on the pump, open a faucet slightly and follow the noise. It's probably fairly close to the other side of the wall where your fresh water tank is filled.
It's probably in a cabinet with hinges on one side and a single hinge in the middle of the other keeping you from opening the door. On ours it's under the vanity in the bath, and I removed the one holding it shut and put a regular cabinet latch on it. The cabinet with the converter was the same way.
2017 Open Range - Light 297RLS, BX1 Gooseneck
2014 Ram 2500 4x4 CCSB 6.7L 68RFE
offroad is offline   Reply With Quote
Old 11-02-2014, 06:32 PM   #3
Also problem with water pump location
Greetings all. Just joined this forum.
I purchased my third TT this summer; a FR Grey Wolf 29BH with the outdoor bar and grill. I have always winterized my RVs myself. My Grey Wolf, however, has proven a challenge.
I can't find the water pump. I've looked under all sinks and pulled away walls but am stumped. Even turned it on to run water and can't chase down the source of the sound of running pump. It seems to be in the back half. Also tried from the outside. Anyone know this trailer?
Appreciate the help!
tburgh is offline   Reply With Quote
Old 11-02-2014, 07:27 PM   #4
Water Pump Location
Dick
It's under the floor of the bathroom sink cabinet base. You add antifreeze there too.
It's a PIA to get to.
jwedell is offline   Reply With Quote
Old 11-09-2014, 06:05 PM   #5
Traveling Two
jerryliving's Avatar
Mine is located in the front storage compartment behind a small wall cabinet.
jerryliving is offline   Reply With Quote
Old 11-12-2014, 03:25 PM   #6
Buckskin
Mine is located under bathroom sink. You have to remove 4 screws and 2 panels to access. Replacing screws with hanger screws (wood screw on one end and machine threads on other). Have to remove 4 screws to get to water heater bypass valves; will also replace with hanger screws from Home Depot. Next time just have to reove nuts or wing nuts.
Buckskin is offline   Reply With Quote
cat, location, pump, water, water pump
