Originally Posted by moadeeb
Thank you Dave and jeerme, I really appreciate your input and valuable help.
jerrme, unfortunatly the SP-260 didn't come with a winterize kit. I bought one from the local RV shop and will install that tomorrow after work. I also bought a tool to blow the lines prior to running antifreeze through the lines. RV shop said go no higher than 30 PSI and that should do the trick.
moadeeb, my 2012 sp260 '10th anniversary edition' comes with a quick connect winterizing hose. you disconnect the hose coming to the pump from the fresh water tank and connect the quick connect hose to the pump and then drop it into your antifreez jug. my pump is located beneath the lowest drawer just befor you go into the bathroom.
