Old 06-06-2016, 10:14 PM   #1
What are interior Surveyor walls made of?
What material is under the wall covering material? OSB? Is it the same for interior walls as exterior? I wish there was some detailed documentation from Forrest River about how our trailers are made. Thanks!!
2016 FR Surveyor 251RKS. Mods (so far): 2nd battery with solar battery tender, cover, Air Maxx vent covers
Living4Christ is offline   Reply With Quote
Old 06-06-2016, 10:23 PM   #2
acadianbob's Avatar
Here's what I think but others may know different.
Exterior: Fiberglass
Frame: Aluminum
Interior: Hard board
Wall Interior: White Foam Insulation
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 06-07-2016, 08:31 PM   #3
Thanks, I'd be curious on the thickness of the hardboard & insulation.
Old 06-07-2016, 09:50 PM   #4
dmchapman's Avatar
You might try taking a peek where the water heater access or fridge access panels are. You should be able to view a cross section of the wall. Same is true of the ceiling...take off a vent or skylight plenum.
dmchapman is offline   Reply With Quote
Old 06-07-2016, 09:51 PM   #5
Good lead...thanks!
Old 06-16-2016, 07:47 PM   #6
MOD Guy's Avatar
Frame: Aluminum
Almost.
Interior walls are 1/4" lauan wood paneling with deco vinyl covering. I cut holes in them enough to know
Chuck Roder & Family
'07 Surveyor SV-235RS & '16 Chevy Silverado 2500HD (Gas) Crew Cab
High Springs, FL.
MOD Guy is offline   Reply With Quote
Old 06-17-2016, 11:34 AM   #7
schrederman's Avatar
My interior walls are 1/8" luan (cheap) plywood. 1/4" luan would be heavier, but unfortunately not a lot stronger. I wish the RV industry would come up with some other lightweight material because luan is highly susceptible to water damage. There's a layer of it under the fiberglass exterior on most trailers. That's where delamination comes from in most cases. If the luan gets wet, it separates.
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
Old 06-17-2016, 08:33 PM   #8
acadianbob's Avatar
Some Surveyor models are 1 1/2" of foam. Our 5er has 2".
Old 06-19-2016, 05:06 PM   #9
Thanks everyone!!! Much easier to start doing some mods now that I know what I'm working with. I really wish the RV manufacturers gave us some specific detail on things like this & commonly replaced part numbers (instead of a generic Forest River manual that generally covers their entire line-up)
surveyor
