Old 06-22-2011, 09:06 PM   #1
What Surveyor to Buy?
Looking at buying my first travel trailer but don't want to overload my TV. I have not had any success finding the towing guide for my truck - 2003 Dodge Dakota Quad Cab, 4.7 V8, 2WD, 3.55 axle ratio. Does anyone have any idea where to find the towing guide? - and any experiences with towing comfortably with this vehicle. We have looked at the Surveyor SP-220 (dry ship weight 3913 lb) and the Surveyor SV-264 (dry ship weight 4308 lb) - not sure if either would be ok?
Deeker is offline   Reply With Quote
Old 06-22-2011, 09:16 PM   #2
I just tow the TT for DW!
kamp k's Avatar
See if this link will help.
http://www.trailerlife.com/images/do...owingguide.pdf
2008 Ford F350 King Ranch Lariat SD CC 4x4 V10 4:10
2012 Rockwood Windjammer 3008 - Equalizer 12k
2007 EZGO TXT Lifted/Custom Golf Cart
Nights Camped: 2011(52) 2012(65) 2013(65) 2014 (51) 2015 (40)
kamp k is offline   Reply With Quote
Old 06-22-2011, 10:42 PM   #3
acadianbob's Avatar
The 264 would be too much for your truck IMO. A brief google search turned up a max tow capacity of 6,200; but it may vary with engine and rear axle ratio. That dry weight is misleading. Option packages will add a good 500 pounds. Then add liquids; e.g. fresh water and maybe some grey and black from time to time; 8lb/gallon approximately. Then add your food, gear, kitchen supplies, etc. and you will be well into 5,000+ territory.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
