Forest River Forums
Sunline User Photos
Old 10-02-2011, 12:16 PM   #1
M_Mikey
mamentt's Avatar
Where is the low point drain & how much?
I have a SV264 2010 model, and was looking for the low point drain. I assume it is the pipe under the trailer near the fresh water intake near the kitchen door? First time for me to winterize.
I was going to try the pressure winterize method this year to remove the water from the pipes.
Question, how much antifreeze should be put in the gray and black tanks?
mamentt is offline   Reply With Quote
Old 10-02-2011, 12:29 PM   #2
Lou Amadio
herk7769's Avatar
What RV antifreeze flows into the black tank when I winterize the toilet is enough to keep the dump valve from freezing shut.
What RV antifreeze flows into the gray tank from dumping straight RV antifreeze into the traps will do the same for your gray tank dump valve(s).
Oh, these are the low point drains.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 7)
herk7769 is online now   Reply With Quote
Old 10-04-2011, 12:26 PM   #3
M_Mikey
mamentt's Avatar
Thanks for the picture, I assumed right this time. But, I wanted to be sure.
Old 10-04-2011, 12:29 PM   #4
too fast turbo sled
f1100turbo's Avatar
another satisfied customer !
2005 silverado 2500hd pro ride 5th
2011 palomino sabre 32 bhok-6
2012 arctic cat f1100 turbo limited edition sno-pro
Ron and Amy Benhart
2012 nights camped (5)
f1100turbo is online now   Reply With Quote
Old 10-04-2011, 12:50 PM   #5
Moderator
mtnguy's Avatar
Besides the 2 low point drains shown similar to the photo in Lou's post, there is probably a drain for your fresh water tank.
If you are going to blow the lines, the 2 low point drains should probably be capped during that process. That allows you to pressurize the system, and then blow through each valve at each faucet. With the caps removed, all of the pressure will go out the low point drains.
Chap & DW Joy in Ruckersville, VA.
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
mtnguy is offline   Reply With Quote
» Online Users: 128
20 members and 108 guests
bean, Biscuit, bojack, boubou, campfirefun, dec1952, Earth Station, f1100turbo, herk7769, Hoo Dad, kybaja, Mattpopp, mike54, poohbearntigger2, RickV, sellis1053, sfrye5853, tentcamper1, tfedd, wagon52
Most users ever online was 996, 05-22-2012 at 11:04 AM.
Close [X]
