12-03-2011, 04:46 PM
Winterizing
We've had our surveyor for a couple of years, I've never drained the hot water heater. If I should is it the plug at the bottom. Thanks in advance for the help
12-03-2011, 05:08 PM
Well, that's where my hot water plug is, at the bottom. If water comes out when you remove the plug you're talking about...it is indeed, the hot water drain plug.
"If everything seems to be going well, look around, you've obviously overlooked something."
12-03-2011, 05:12 PM
Thanks for the help. That was it...never thought about draining it before. Got lucky I guess. Thanks again
12-06-2011, 01:44 PM
Moderator
Wow! You must live somewhere WARM!!
I think the annual draining is a good thing from a sediment perspective too; although you might not have much if you are filtering your water. Get "punk" water out of there too . . .
2012 F150 FX4 Ecoboost, 2008 Surveyor 235RKS
2003 Yamaha FJR1300, Reese Dual Cam WD
1969 John Deere 1020, 1940 Ford 9N
Jonsered 535, Can of WD-40, Hostess Cupcakes
12-06-2011, 01:51 PM
Moderator
Also, it is good to check the anode rod to make sure you have plenty left for the next season.
Chap & DW Joy in Ruckersville, VA.
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
12-06-2011, 03:37 PM
What is punk water and anode rod? All I've ever done is drain the fresh tank and take the inline filter off the water line, learned the hard way on that one
12-06-2011, 03:50 PM
Moderator
The anode rod is located on the back of the drain plug if you have a Suburban water heater. It is meant to deteriorate due to galvanic exchange to save the other metal parts of your water heater.
Here is a gently used one with plenty of life left:
Not exactly sure what Bob was referring to as "punk" water, but it is good to flush all of the sediment out of the bottom of the tank yearly.
2008 Surveyor 263
12-06-2011, 04:01 PM
Thanks, my plug had a black plastic rod on it but nothing like that
12-06-2011, 05:57 PM
Moderator
A picture would be good.
If it is a Suburban water heater, I think it should have an anode rod.
2008 Surveyor 263
12-06-2011, 10:28 PM
Could it be because all but the center rod is used up?
Everett & Joan after 57 years together.
2004 1/2 ton Chevy & 2011 Rockwood 1809S
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 152 |
| 23 members and 129 guests |
| bean, bikergirl, Biscuit, bojack, boubou, campfirefun, dec1952, DF5.4, Earth Station, f1100turbo, herk7769, Hoo Dad, kybaja, LFugate, Mattpopp, mike54, poohbearntigger2, RickV, sellis1053, sfrye5853, tentcamper1, tfedd, wagon52 |
| Most users ever online was 996, 05-22-2012 at 11:04 AM. |
