Old 05-29-2012, 07:50 AM   #1
'06 GS 272 Question
I have a couple of question regarding dumping the black and gray water tanks. I have 2 handles on each side of the tube where everything exits. Neither handle says what it is for. There is a sticker on the side of the rig that says waste water connection and another that says sewer hook up. Does anyone have any idea on which handle is for the gray water and which is for the black water?
Also, does anyone have any idea on what to use to lubricate the pulls to make them easier to open and close?
Any help is appreciated.
Cpapkt is offline   Reply With Quote
Old 05-29-2012, 07:54 AM   #2
TURBS's Avatar
The bigger of the two tubes is black the smaller is grey
Old 05-29-2012, 08:01 AM   #3
I cannot see the hoses for each tank. The underbelly is sealed and insulated. All I have is the hose to connect my dump hose to and then one handle on each side.
Old 05-29-2012, 08:35 AM   #4
If you can dump the tanks, then you can figure it out. With the tanks empty, handles closed, turn on the water in the sink, and run at least 2 minutes. With the water still running, go out and pull one handle, if nothing, close it and pull the other. Should be the gray tank dump handle. Good Luck
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
