Old 10-25-2008, 09:13 PM   #1
Unhappy 2003 GS 272 Front Storage Leaks..
I have the 2003 Grand Surveyor, and I love the Trailer. My front storage compartment right above the tongue leaks. Has anyone else ever had this problem? Any good solutions? I think I know now why they quit making these front starage compartments. I have tried using rope caulk, and foam tape. Maybe I can find replacment seal, I do not know where to find it though. I have heard on another site that it might be the piano hinge that they use to open and close the door. Any help from someone who knows would be greatly appriciated.
smokinjoe is offline   Reply With Quote
Old 10-25-2008, 09:29 PM   #2
Head Rambler
Camping World carries several profiles of trim. I replaced all my storage door seals with a slightly larger "D" profile than the factory installed and it worked great. They're a little harder to close but that's a good thing. If you have a special profile you might try Trimlok Rubber Seals.
Gotta go campin!
Old 10-25-2008, 09:51 PM   #3
Wink Trim seal..
Did you actually try this seal at Camping World? I found some there sold in 25' length 3/8"x3/8" or 1/2"x1/2" the D loop style looks like the ticket.
I wonder why Forest River made the door like this?
Old 10-26-2008, 06:26 AM   #4
Grape Escape
We had a Traillite with front storage as yours does and put a 2" wide strip of white fiber reinforced tape along top hinge which stopped water from getting in
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 10-31-2008, 08:56 PM   #5
Look at Lowes where they carry weatherstripping. They have some nice D style in various widths and thicknesses.
John U
2007 Rockwood 8315SS
2014 Silverado 2500HD 6.0L
midnightpumpkin is offline   Reply With Quote
Old 01-03-2009, 03:05 PM   #6
CHAINSAW OPERA
I gotta leaker too
I did all the d-seals that every one else is using BUT
I also used jeep holdown latches to pull the door tighter closed.
And if any water does get in while in storage I installed a extra floor/sink drain
Home depot. Replaced other floor vent with a drain then sprayed
pick-up bed liner / rubber 12 inches up on all sides.
If its worth doing its worth overdoing !!
Good Luck
CHAINSAW OPERA is offline   Reply With Quote
Old 02-19-2009, 09:23 PM   #7
I have had this problem too!! I installed the Trimlok and seems to fit a lot better than the original did. I installed it late last fall so I have not had a chance to see if it is any better. I hope this helps I think by the quality of the seal it should work great for this!!!!
grand surveyor
