Old 09-03-2015, 10:16 AM   #1
current drain
I have a 2004 surveyor. If left for a couple weeks the batteries are depleted. What might cause this? I pulled fuse 5 for the tv/stereo and there is a spark (drain) when I reconnect it. What else could be on this circuit? Thanks
jonboy435 is offline   Reply With Quote
Old 09-03-2015, 02:30 PM   #2
Head Rambler
The propane detector is powered from the battery. I'm not sure if your fridge control board requires 12 volts, but if it does then it constantly draws a tiny bit of power even when it's off.
Gotta go campin!
Old 09-03-2015, 10:00 PM   #3
bikendan's Avatar
modern RVs have numerous parasitic power drains.
unless you keep it plugged into shore power or install a battery disconnect switch, your battery will be dead in a few days.
Equalizer WDH
drain
