Old 07-10-2018, 07:04 AM   #1
OswegoLion's Avatar
Do Max Air fans close automatically?
Rain possible later and won’t be home? Help?
OswegoLion is offline   Reply With Quote
Old 07-10-2018, 07:08 AM   #2
The versions with rain sensors do. For the deluxe models with the intergrated cover it’s not necessary for it to be closed to keep the rain out.
That being said there are so many model variations both retail and OEM it’s impossible to say without an exact model number.
2017.5 Forester 3051S
2019 Jeep Trailhawk toad
Steve-W is online now   Reply With Quote
Old 07-10-2018, 07:12 AM   #3
Ret E-9 Anchor-clanker
donanddona's Avatar
Until proven to work (even if the dealer told you so), error on the side of caution and Close it. My vent cover will allow small spray or mist inside on heavy rains.
donanddona is offline   Reply With Quote
Old 07-10-2018, 07:23 AM   #4
rsdata's Avatar
If you have the type with the vent cover, covering the open/close vent lid, then I would not worry about it. If you don't have that vent cover then get it...
https://smile.amazon.com/Maxxair-503...70_&dpSrc=srch
Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
Old 07-10-2018, 07:47 AM   #5
This Can be a Trick question! The "Maxxfan and Maxxfan Plus" have Tabs so you CAN just "Buy the FanMate Cover and Install with Clips" No Tools needed! You can also Buy a" Maxxfan Deluxe which has its own Rain Shield and Requires No additional Cover! MaxxAir makes "Other Style Covers" but the "FANMATE" cover works on the Auto Close fans! Youroo!!
Old 07-10-2018, 07:58 AM   #6
As others said, depends on the model. The ones that came on our Rockwood have both covers and rain sensors. They have a sticker with a little blue umbrella on them. They stay open in a light rain, but in a heavy downpour there's enough spatter to trip the rain sensor and close them. (You also should clean your sensors with a toothbrush or abrasive sponge every year. We had one fail on our last rig because it was dirty. Soaked the bed.)
stephndudb is offline   Reply With Quote
Old 07-10-2018, 08:09 AM   #7
https://www.amazon.com/Maxxair-503-1...=rv+vent+cover
2016 Microlite 21DS
2014 Ram 1500 QC 6 cyl. 8 spd.
Blue Ox SwayPro
windsurfdog is offline   Reply With Quote
Old 07-10-2018, 08:15 AM   #8
Originally Posted by windsurfdog View Post
These covers are Not recommended for High Output Fans! They are OK for covering 14X14 Vent openings or the Old 4 Blade "Noise Maker Bath Fans" but Very restrictive for Big CFM Fans! Youroo!!
Old 07-10-2018, 08:25 AM   #9
Had I noticed your previous post with the Amazon url, I would not have posted mine.
That said, I see no difference between the one I posted and the one you posted...dimensions are the same...only difference is color...yet one says something about not suitable for high output as you said. You see any differences? I bet they are none.
2016 Microlite 21DS
Blue Ox SwayPro
Old 07-10-2018, 08:32 AM   #10
Sorry but My Post # 5 says Nothing about the Little Covers you posted about! MaxxAir list Many Covers,yours is the Smallest! Youroo!!
Old 07-10-2018, 08:36 AM   #11
Look at your post #4. The vent you mentioned there has the same dimensions as the one I posted.
2016 Microlite 21DS
Blue Ox SwayPro
Old 07-10-2018, 08:50 AM   #12
Hey I didn't Post #4 ! Youroo!! PS I posted # 5 and #8!
Old 07-10-2018, 08:53 AM   #13
My bad...sorry...
2016 Microlite 21DS
Blue Ox SwayPro
fan
« Leak from tub | - »
