Old 11-02-2014, 11:09 PM   #1
Fan-Tastic Vent Hook-up
Does a Fan-tastic fan have to be completely hooked up and anchored before it will activate? There are only basic instructions that came with the fan and nothing about other possible procedures. I have a new one I'm installing and have it wired properly but it won't run. I've checked all house wires for power and continuity and all reads properly. I've checked all fuses and all are good. Power is getting to the fan as indicated by a volt meter but nothing is working so far. I've checked all fan switches and settings with no luck. I even checked with an older fan with the house wires going to the fan but now no luck. It did work previously. I tried to connect the old one to a different outlet and again no luck. Other electric items work at the same test outlet.
So does the fan have to be hooked up and anchored before it will work?
bobandpatsyrvers is offline   Reply With Quote
Old 11-02-2014, 11:18 PM   #2
Campster's Avatar
I believe the lid needs to be open, some also have a knob to control the temperature. Make sure it is turned all the way down. Other then those things i'm not sure??
Campster is offline   Reply With Quote
Old 11-02-2014, 11:21 PM   #3
All that has been tried. Thanks for the response.
Old 11-02-2014, 11:22 PM   #4
X2 on Lid up! Youroo!!
Old 11-05-2014, 11:02 PM   #5
Are you connecting to 12vdc or 120vac?
Sirsea is offline   Reply With Quote
Old 11-06-2014, 01:58 AM   #6
After checking everything and all tests showed no problems, other than it not working, I took the vent/fan to Camping World. Their installer check the fan himself and found it faulty. They replaced it with no questions asked. I now have it installed and working as it should.
Thanks for your reply.
Old 11-06-2014, 08:38 PM   #7
Campster's Avatar
Glad you got things resolved....
fan, vent
